Studded 6.0 Torque??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 09-28-2009, 04:01 AM Thread Starter
Just finished replacing the head gaskets and studding my 2004 6.0. How many times shoud i heat cycle my engine before i bolt the cab back on? Any help would be much appreciated
ar-mike is offline
post #2 of 22 (permalink) Old 03-11-2010, 01:18 AM
Specializeddieselnw's Avatar
Re: Studded 6.0 Torque???
There is no need to retorque the studs. Just put the cab on and drive it for a while and keep an eye on things such as oil and water temp and fluid levels.
Specializeddieselnw is offline
post #3 of 22 (permalink) Old 03-11-2010, 01:23 AM
PETE ENGR PSD
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #4 of 22 (permalink) Old 03-11-2010, 03:33 AM
It isn't a necessity but if you have the time... I would break each nut loose, one at a time, and retorque in the original sequence. Then heat cycle it at least once then when it is stone cold again go back and re torque with out breaking loose. This whole crap about the fastners holding the head down having become a non serviceable item is crap. Studs rule, don't be afraid to retorque.
BoredandStroked is offline
post #5 of 22 (permalink) Old 03-13-2010, 02:06 AM
...Besides you should be using the torque angle method, which is based on turns of the nuts, not actual torque because it can be inaccurate.
post #6 of 22 (permalink) Old 03-13-2010, 02:10 PM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
Where on the instructions in the box of studs does it say to turn them in degrees?
Inaccurate would be your post.
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #7 of 22 (permalink) Old 03-13-2010, 04:11 PM
40 lug nuts
Snake's Avatar
For factory head bolts, yes.
For aftermarket head studs, no.
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
post #8 of 22 (permalink) Old 03-13-2010, 06:47 PM
Turbo99's Avatar
The torque angle is the ONLY way that I got my heads to seal w/ studs over 525hp, we did them 3 times and the last time we used the torque angle method and it held and no other changes were made, BDP did it and I believe this is how they install their studs now. My had no issues after the last install and did 587/1200.
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 10.80 @ 131mph
Turbo99 is offline
post #9 of 22 (permalink) Old 03-13-2010, 08:53 PM
Proud Sponsor
Abrannan19's Avatar
Jeremy, that worked once..Not saying it wont work again, but has Beans started to use this method on all 6.0's that come in the shop for studs? Also you only had your truck back for 3 months (estimate) with no puking, which IMO isn't a real big feat, now if you were talking years, then that would be another story with some good backing. This isn't any disrespect to your or Beans, I am just making a statement. The truck at hand is also gone now too..
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #10 of 22 (permalink) Old 03-13-2010, 09:22 PM
Turbo99's Avatar
Well seeing how ALL things were constant in 3 tries set-up,installer,tuning everything and the other sets didn't hold more than a week or two, I would say it fixed it. I am not sure why you feel so strongly against it you and a couple others seem to have a issue w/ anything that is different than ARP says, and the FACT of it is we tried their way twice and 0 success. BDP tried alittle out of the box thinking and came up w/ a way that was between the stock torque angle method and what the Fastner companies wanted, and it worked.
Jeremy
Turbo99 is offline
