Mass Air Flow Sensor? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-25-2009, 01:24 AM Thread Starter
I dont have a Mass Air Flow Sensor is it worth putting on since i am soon getting a new intake? The plug is there, is it as simple as plug and play?
4x4freak is offline
post #2 of 13 (permalink) Old 09-25-2009, 01:36 AM
06powerstroke's Avatar
Re: Mass Air Flow Sensor?
Did someone remove it. Or do you just have a IAT instead? I think the 03/04's don't have a maf...
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #3 of 13 (permalink) Old 09-25-2009, 02:11 AM
Everybody poops <~ see?
dennisr_f350's Avatar
Send a message via MSN to dennisr_f350
Simply removing it would produce a DTC, and a 'check engine' light.
4x4freak, what year is your truck?
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
dennisr_f350 is offline
post #4 of 13 (permalink) Old 09-25-2009, 02:14 AM
Yeah, it's like that
ducatirider944's Avatar
Mine is an 04' and has a MAF, but the intake I bought had an insert for it
ducatirider944 is offline
post #5 of 13 (permalink) Old 09-25-2009, 04:48 AM
I thought there is a year that doesn't have a MAF, my intake came with a MAF hole cover in case you just had an IAT...
post #6 of 13 (permalink) Old 09-25-2009, 02:49 PM Thread Starter
mine is an 05 and yes it has the IAT
4x4freak is offline
post #7 of 13 (permalink) Old 09-25-2009, 02:51 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
I ran mine for quite a while without it being plugged in. No codes what-so-ever. Went ahead and plugged it in just to see if anything would change and there was zero difference.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #8 of 13 (permalink) Old 09-25-2009, 06:26 PM
Then here I stand, corrected.
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
post #9 of 13 (permalink) Old 09-25-2009, 11:25 PM
There was a series of either late '04 or early '05 that they did without the MAF, I think early '05 when they used the EBP sensor again. My '03 throws a CEL if its unplugged because it uses the inferred EBP strategy and requires the MAF.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #10 of 13 (permalink) Old 09-25-2009, 11:28 PM
motoxracer42's Avatar
from what i was told some of the 05s didnt have a maf sensor they just had iat. you need one or the other. it is needed for fueling. on my 06 it throws a code if its unpluged.
06 crew cab
06 reg cab
motoxracer42 is offline
