My EGR cooler solution - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 09-24-2009, 08:52 PM Thread Starter
I have an 03 with 96k miles. As far as I know, the cooler is just fine. But I'd like to, at the minimum, block the gases. I've read up on this and the simplest way to fix the EGR problem is to just put a block plate between the cooler and the up-pipe correct? Then I can just clean out the EGR valve, leave it there, and let it do it's thing without getting CEL's?
1. Does anyone have the dimensions for the block plate? Radius and thickness?
2. How is the installation of it done? Does anything major, like the intake manifold, or turbo, need to be removed? Do you get to it from under the truck or over and behind the engine?
2003 F250 King Ranch Crew Cab FX4 6.0L
Purchased 9-10-09
Stolen 12-3-10
Texas-KR is offline
post #2 of 12 (permalink) Old 09-24-2009, 09:15 PM
Proud Sponsor
Abrannan19's Avatar
Re: My EGR cooler solution
We offer full delete kits and solid up pipes to block off exhaust gases.
Up Pipe: First Coast Diesel Performance -Solid Up Pipe- Your Source For Powerstroke Performance
Full delete kit: First Coast Diesel Performance -Full EGR Delete Kit- Your Source For Powerstroke Performance
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #3 of 12 (permalink) Old 09-24-2009, 09:27 PM Thread Starter
Thanks, but doing it my way is free. lol I don't have $500 right now, and I really want to do the preventative maintenance.
Purchased 9-10-09
Stolen 12-3-10
Texas-KR is offline
post #4 of 12 (permalink) Old 09-24-2009, 09:39 PM
Hate 'R Us
!!!PainTrain!!!'s Avatar
I'm pretty sure the cooler can still crack or fail even with it being blocked off.
!!!PainTrain!!! is offline
post #5 of 12 (permalink) Old 09-24-2009, 10:06 PM Thread Starter
I don't think it will with no gases running through it. However, if the cooler is blocked off on both ends, then it won't matter. The coolant veins may burst and fill the tank with coolant, but it won't enter the motor or exhaust.
Purchased 9-10-09
Stolen 12-3-10
Texas-KR is offline
post #6 of 12 (permalink) Old 09-25-2009, 02:10 AM
i did the crack pipe mod. but it gets rid of the cooler. don't know what emission testing is like in your state. picture i used for reference. do a search on other ford truck forums and you will find more info if interested. course you need or need to know someone who can weld.
scameron is offline
post #7 of 12 (permalink) Old 09-25-2009, 02:28 AM
jdgleason's Avatar
elite has the blocker plate its like 30 bucks
'09 F350
-JD
jdgleason is offline
post #8 of 12 (permalink) Old 09-25-2009, 02:37 AM
Everybody poops <~ see?
dennisr_f350's Avatar
Send a message via MSN to dennisr_f350
It'll just be contaminated with hundreds of tinfoil like cooler fins, no biggie...
2007
F350 SuperDuty
Some air
Some fuel
Some grip
Some guages
The usual suspects.
dennisr_f350 is offline
post #9 of 12 (permalink) Old 09-25-2009, 11:26 AM Thread Starter
^^^ ""Contaminated?" As in you think all the fins are going to break off (without the exhaust heat being there), then travel back through a pinhole into the coolant system? lol
Thanks. I saw the plate, but I would need two for both ends of the tank. I know I seem like a cheapass, but $50 for two discs that can be made for free in my garage..... I just need to know the size of the discs.
Worst case, I'll have to pull out the cooler and size it myself THEN do the work to make them. I just didn't want the extra downtime.
Purchased 9-10-09
Stolen 12-3-10
Texas-KR is offline
post #10 of 12 (permalink) Old 09-25-2009, 02:21 PM
Stroker67's Avatar
I know you said you dont want to do a full EGR delete right now, but do yourself a favor and do it right the first time. FULL EGR DELETE from FCDP FTW
Stroker67 is offline
