6.0's running 190's or larger injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 52 (permalink) Old 09-22-2009, 06:45 PM Thread Starter
AllYourBaseAreBelongToUs
imelmo's Avatar
What kind of track times are y'all seeing, ET and mph please? And with what mods?
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #2 of 52 (permalink) Old 09-22-2009, 06:51 PM
Lovin the Tuna
RedSmokey's Avatar
Re: 6.0's running 190's or larger injectors?
motoxracer42 is running some 205's. He just got his twins together and now needs some trany work. But he was running a big single with the 205's before. You should talk to him, i will let him know about this thread, he has some runs down the track.
Here is his twin build.
6.0L Powerstroke Twin Build - Powerstroke Nation
2001 F250
2000 F250
RedSmokey is offline
post #3 of 52 (permalink) Old 09-22-2009, 06:52 PM
Busy Busy
Marty's Avatar
I've seen two crew cab long beds weighing in at 7800-8000 lbs.
Industrial Injection 190's, 300 shot of spray, 03 turbo, Innovative tuning... 12.5's at 107-108 mph with 1.7-1.75 60's.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #4 of 52 (permalink) Old 09-22-2009, 07:59 PM
woodduck97's Avatar
Is the 03 turbo able to hold more boost?
1997 Ford F-250 Sleeper Edition
woodduck97 is offline
post #5 of 52 (permalink) Old 09-22-2009, 10:01 PM
redracer62's Avatar
II 225's, 64mm single, [email protected], 1.75 60ft. the only good run with spray i bent 6 rods . CCLB 8200LBS.
06 F-350
Trusted Performance
[email protected] #2
550hp 970tq
redracer62 is offline
post #6 of 52 (permalink) Old 09-22-2009, 10:52 PM
diesel-kid's Avatar
red racer, what are your dyno numbers?
diesel-kid is offline
post #7 of 52 (permalink) Old 09-22-2009, 11:02 PM
redracer62's Avatar
515hp 914tq. that was with blown HG's and my old turbo. i aslo think the dyno didnt load it enough. going to go back soon and use the spray this time.
06 F-350
Trusted Performance
550hp 970tq
post #8 of 52 (permalink) Old 09-22-2009, 11:18 PM Thread Starter
imelmo's Avatar
Where do you get that weight from?
imelmo is offline
post #9 of 52 (permalink) Old 09-22-2009, 11:22 PM Thread Starter
imelmo's Avatar
Yeah, even if your truck only weighed 7800lbs that 102mph trap speed would put you in the neighborhood of 560rwhp. If you're actually weighed it at 8200lbs that's around 590rwhp.
imelmo is offline
post #10 of 52 (permalink) Old 09-22-2009, 11:31 PM
redracer62's Avatar
i got that when i went to the dump, only had a 200 lbs or so in the bed, i just geussed, it might be a little high, but i know its heavier than 7800. i need to get it on a scale to get an accurate weight.
06 F-350
Trusted Performance
550hp 970tq
