Torque angle vs. Torque Ft. LBS. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 42 (permalink) Old 09-18-2009, 11:57 PM Thread Starter
Turbo99's Avatar
When everyone is studding , what are you doing are you using the stock torque angle method or torquing to ft.lbs?
Has anyone ever checked a stock torque angle to see what it actually is in ft. lbs? If so what was it?
Just thinking about reasons to stop the blown HG's from the stand point thinking that the ARP torque could be flexing the head and/or gasket at the stud and maybe less torque could be the answer to not flexing the head but also has to be enough to hold up to the CP's and not lift the head.......just clamp it enough that it is FLAT and true.
Discuss
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 10.80 @ 131mph
Turbo99 is offline
post #2 of 42 (permalink) Old 09-19-2009, 12:51 AM
Re: Torque angle vs. Torque Ft. LBS.
Last time I stuck a torque wrench on a stock head bolt I think I got around 200-210ftlbs. The problem with the TTY head bolts is they will continue to stretch if cylinder pressure is high enough.
Jay03GT is offline
post #3 of 42 (permalink) Old 09-19-2009, 01:12 AM
taking a tq reading off a stock head bolt may not be accurate since they are tq to yield. With that said on new installed stock bolts i have found around 245 so same as arps. Also take into account that not all tq wrenches read the same accuracy, etc.
Anyway as for head studs i would also question how many retourque thier head studs.
I will tell you my scenario. I tourqued my head studs to 260 ft.lbs. however that was at the limit of my tq wrench so that is not the most accurate area of a tq wrench. I double checked it with another tq wrench. I ran a heat cycle and rechecked = no movement.
I then used my truck, towing , etc. I do not race my truck or run any hi power tune or anything like that, but like i said i do tow.
Anyway jump to nearly a year later, i filled up at a local fuel station and they had made a goof and had gas in their diesel and diesel in their gas. (delivery truck got it bassakwards)
So the result was 8 new injectors and retourquing of the head studs while i was in there. This time i tq my studs to 245 using the same tq wrench and guess what, some of them moved and were undertorqued.
Now sure i guess some could say me overtourquing stretched them, but an extra 15 lbs is nothing considering a tq wrench is not even that accurate at that tq, aswell if arp's can't take a little extra then whats the point.
Bottom line is my head studs required a retourque after i worked the engine. (which is why ford and other manufacures went to a tq to yield bolt in the first place)
BTW my truck does not puke a bit with studs, but no racing just towing continous loads for a few hours at a time. So at this point i feel a retourque of head studs is required, but thats just me.
sonic blue l is offline
post #4 of 42 (permalink) Old 09-19-2009, 03:39 AM Thread Starter
Turbo99's Avatar
My main question was for useing the stock type ANGLE torque which is not a ft.lb measurement, it would be say 50ft. lbs. 1st pass and second would be 360* more than the 1st and the final pass would be 90* more than the 2nd.
I wanted to know if anyone has checked what that actually comes up to ft. lbs.
That is interesting about the studs being loose after a 1yr of running.
Jeremy
Turbo99 is offline
post #5 of 42 (permalink) Old 09-19-2009, 12:16 PM
I would follow the manufacturers torque recomendation on this. ARP's are not a TTY design.
Jay03GT is offline
post #6 of 42 (permalink) Old 09-19-2009, 04:43 PM Thread Starter
Turbo99's Avatar
done that twice already.........still blown......looking for a change.
Jeremy
Turbo99 is offline
post #7 of 42 (permalink) Old 09-19-2009, 04:53 PM
Vozar's Avatar
Go with h-11's
99.5 F-250 7.3 4x4
Vozar is offline
post #8 of 42 (permalink) Old 09-19-2009, 06:13 PM Thread Starter
Turbo99's Avatar
we are pretty sure that the torque for the studs is flexing the head. The studs ARE NOT stretched the y have been checked. The studs are holding the ....on most application inbetween the studs dead center is where they leak which indicates the studs holding and the head flexing.
Jeremy
Turbo99 is offline
post #9 of 42 (permalink) Old 09-19-2009, 08:01 PM
What is done to your truck? I assume you have put a straight edge on the heads and the block. IMO torquing the head studs less isn't gonna keep from blowing headgaskets, you have something else going on or are exceeding the limit of what the studs can take. What headgaskets are you using?
Jay03GT is offline
post #10 of 42 (permalink) Old 09-19-2009, 08:10 PM
Just weld a bead around the outside of the heads between the block and head...that oughta do the trick!
but really, hope you get it figured out!
Rubenk is offline
