Trans issues? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-14-2009, 10:46 PM Thread Starter
jdgleason's Avatar
Trans issues?
I have a 5r110 and when the converter locks and i lean on it a little i get a shudder. I know its in the drive train, almost feels like the engine cuts out but im almost positive that isnt it. Its not throwing anyt codes except for every so often i will get the throttle position sensor code. Also, I am getting a hesitation to shift into gear, as well as engaging and disengaging several times in reverse. Stock tranny with an ats converter. Anyone know whats goin on?
'09 F350
-JD
jdgleason is offline
post #2 of 5 (permalink) Old 09-15-2009, 01:24 AM
Brentos's Avatar
Re: Trans issues?
i have heard of similar issues when the lockup solenoid went out. but when you describe what it does in OD i would lean towards a injector miss?
Brentos is offline
post #3 of 5 (permalink) Old 09-15-2009, 02:01 AM Thread Starter
jdgleason's Avatar
Re: Trans issues?
Thats what I would immediately think, however my injectors are almost brand new... like 3k on them. And wouldnt that throw a code?
'09 F350
-JD
post #4 of 5 (permalink) Old 09-15-2009, 02:22 AM
Brentos's Avatar
Re: Trans issues?
not neccisarily. that kind of a miss normally doenst. would have to hook it up to a scanner
Brentos is offline
post #5 of 5 (permalink) Old 09-15-2009, 03:04 AM Thread Starter
jdgleason's Avatar
Re: Trans issues?
ok.... ill have to do that
'09 F350
-JD
