Procharger question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 62 (permalink) Old 09-14-2009, 02:35 PM Thread Starter
Extended Power's Avatar
Procharger question
Since the Procharger is belt driven:
What happens to all the boost when the truck shifts gears after hitting 4000 rpm? (How is the turbo protected? Since the air cannot go into the engine, it pushes backwards, through the turbo. -End to end play.)
Why not just install a bigger Procharger, and get rid of the turbo altogether? (I think that it would be easier to just run the Procharger outlet into the intercooler...done.)
Off idle, I can see that the Procharger would make boost instantly, and keeps a positive pressure on the turbo intake.....
Is there a point where an aftermarket turbo would actually "Pull" air through the Procharger, once it lites?
2003 F-350 KingRanch 4x4
Extended Power is offline
post #2 of 62 (permalink) Old 09-14-2009, 06:07 PM
Re: Procharger question
The procharger is a centrifugal type supercharger they make boost dependent on rpm. Off idle = no boost
'06 6.0 FX4
coposrv is offline
post #3 of 62 (permalink) Old 09-14-2009, 06:27 PM
Snake Oil Salesman
mattr66's Avatar
The supercharger needs a secondary compressor to make the boost numbers required for a performance diesel application, that's where the turbo comes in.
What does a little boost hurt at idle? Just like driving below sea level.
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #4 of 62 (permalink) Old 09-14-2009, 06:53 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Just got back from a test drive with the new DI trans installed and I can't seem to wipe the grin from my face, instant torque from a 6 leaker, who da thunk it
I'm sure the new up pipes from Logan over at Centex Diesel had a lil something to do with the added lowend response. Anything past the first 1/4 of throttle travel results in instant white smoke from the tires
You can literally feather the throttle and spin the tires at will in the first 3 gears.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #5 of 62 (permalink) Old 09-14-2009, 07:00 PM
Proud Sponsor
Abrannan19's Avatar
sweet..I ready to see it at the track..tighten up
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #6 of 62 (permalink) Old 09-14-2009, 07:01 PM
WINNING
Countryboy07's Avatar
I want one!!!!!!!!!!!!!!!
2002 VW Jetta TDI
Countryboy07 is offline
post #7 of 62 (permalink) Old 09-14-2009, 11:03 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
I think it'd have to be a pretty big turbo. At full rpm the F1C will fow 1850cfm.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #8 of 62 (permalink) Old 09-14-2009, 11:03 PM
imelmo's Avatar
This is gonna be a loooooooooong couple of weeks.
Weird seein' David post in the 6.0 section.
imelmo is offline
post #9 of 62 (permalink) Old 09-14-2009, 11:19 PM
PSDfan99's Avatar
That's friggin awesome. That would be so much fun on the street.
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #10 of 62 (permalink) Old 09-15-2009, 12:59 AM Thread Starter
Now that's what I wanted to hear!!!!!!!
I can hardly wait for a kit to come out....
