bad injectors? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 09-08-2009, 04:45 PM Thread Starter
Not Winning.
6.0 p-stroke's Avatar
Question bad injectors?
my truck has been starting hard lately, at first i thought maybe it was the ipr sensor, then i noticed a white haze out of my tail pipes, it doesnt seem to run top notch until it is completely warm. i was told this could be a sign of injectors starting to go out, my truck has a little over 200k. what would be a good, inexpensive after market injector?
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
Logan Schneider at CenTex Diesel Performance
830-885-6500
Originally Posted by Powerstroked162 View Post
Lets be honest here, how many times have you been on the receiving end of a "Cleveland Steamer"?
6.0 p-stroke is offline
post #2 of 13 (permalink) Old 09-08-2009, 04:55 PM
Re: bad injectors?
depends on what you want to do with your truck? if your stock ones went 200,000 consider yourself lucky..... Adam from FCDP can help you out, an d i am sure other vendors will chime in as well.....
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #3 of 13 (permalink) Old 09-08-2009, 04:58 PM Thread Starter
Not Winning.
Re: bad injectors?
iv been very lucky with this truck. i didnt blow a head gasket until 185k, and the only problem before that was a warped head at 35k. its my dads old truck
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
830-885-6500
post #4 of 13 (permalink) Old 09-08-2009, 05:00 PM Thread Starter
Not Winning.
Re: bad injectors?
id like to get stage 1s or maybe 2s, i dont wanna kill my turbo or ruin the tranny too soon after the injectors go in though
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
830-885-6500
post #5 of 13 (permalink) Old 09-08-2009, 06:29 PM
Proud Sponsor
Abrannan19's Avatar
Re: bad injectors?
I will PM you a price on stage 1 injectors, they will work fine with the stock turbo and tranny
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #6 of 13 (permalink) Old 09-08-2009, 06:49 PM Thread Starter
Not Winning.
Re: bad injectors?
thanks.
any other inputs or suggestions?
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
830-885-6500
post #7 of 13 (permalink) Old 09-10-2009, 11:25 PM
Extended Power's Avatar
Re: bad injectors?
Suggestion:
Go buy a set of reman's from Ford....then if you still want more power, send the reman's out to be modified, not the ones that already have issues.
And make sure you get your injectors back....not someone else's junky cores.
2003 F-350 KingRanch 4x4
Extended Power is offline
post #8 of 13 (permalink) Old 09-11-2009, 02:06 AM
Yeah, it's like that
ducatirider944's Avatar
Re: bad injectors?
This is what I'm facing right now myself, my truck has the same problem until it warms up. I had 2 injectors and the HPOP changed last year. Looks like I will just change out the other 6 so I'm done screwing with it. How much work is it to get down to the point to change the injectors? I have done a ground off restore on an El Camino and used to road race street bikes so I have some mechanical knowledge. I have never tore into a diesel motor before other than minor things like cold air intakes, exhaust parts. What am I in for?
ducatirider944 is offline
post #9 of 13 (permalink) Old 09-11-2009, 06:06 AM Thread Starter
Not Winning.
Re: bad injectors?
my truck has been torn down and had the cab lifted a few times, if i can remember basically everything on top must go to get the valve covers off. im sure someone will have a more accurate description
Cooper
04 6.0 CCSB fx4
08 6.4 CCSB 4x4
Special thanks to:
830-885-6500
post #10 of 13 (permalink) Old 09-11-2009, 01:50 PM
Re: bad injectors?
You gotta remove the turbo discharge pipe, glow plug module, and oil filler on the passenger side. (To get at the valve cover)
You gotta dump the coolant, remove the de-gas bottle, air filter assembly, and the other coolant lines that run the the degas bottle on the drivers side. (To get at the valve cover.)
First time is a b!tch...after you've done a few, it goes waaaay smoother, and you know exactly what tools you need, and how much time it will take you to do it.
