A few sled pulling ??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 09-06-2009, 01:17 AM Thread Starter
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
Diesel days is 2maro In wyoming and im gonna try to pull the sled so i have a fewquestions should i pull in 4 hi or low range?Any other tips for me wold be awesome Thanks guys ANd sorry for all the questions...and i searched couldnt find much info on sled pulling....
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
post #2 of 9 (permalink) Old 09-06-2009, 01:20 AM
Re: A few sled pulling ???
definitely 4 lo. you won't need anything higher than 3rd gear, manually shifting them usually works good for the 6.0s. Keep it wound out!
2000 F250 Red CCSB.Full Force 238/100s, BTS valve body, T-500. Normal bolt on stuff.
"Because HE Lives..."
bigfords is offline
post #3 of 9 (permalink) Old 09-06-2009, 01:18 PM
Brentos's Avatar
4low start in 1st and shift your way to third gear. fill the back tires up to the suggested cold fill psi, drop the front psi to 30 or so since yours is coil sprung you will want to ratchet strap down the front so it doesnt hop and then hammer down!
Brentos is offline
post #4 of 9 (permalink) Old 09-06-2009, 02:26 PM
if anyone knows i was wondering how heavy those sleds are say for just a dd street truck. i watched them in houston a few years ago and when they got to the end of the pull the street trucks just bogged down and couldnt even turn there tires anymore.
jrfonte is offline
post #5 of 9 (permalink) Old 09-06-2009, 02:33 PM
jdgleason's Avatar
For the work class usually its a 20k hook.
'09 F350
-JD
jdgleason is offline
post #6 of 9 (permalink) Old 09-06-2009, 08:31 PM
really thats it. hmm well on 2nd thought i guess that is a lot of weight to drag compared to having it roll behind you. no wonder they were breaking rear uv joints and squating the rear of the truck and just stalling lol i wont put mine through that kind of torture to expensive to fix. but for those of you that will keep on because i love to watch those diesels pull.
jrfonte is offline
post #7 of 9 (permalink) Old 09-06-2009, 08:46 PM
Black Gold
tmillburg's Avatar
if ur over wieght here are some things u can remove fast, tailgate. back seat, tool box, spare tire..but most likely if ur pullin in a work stock class ull be fine. usually i think its a 10k class. street class is usually 8500, gas diesel challenge is most likely 7500
2011 250. 1.5 in leveling kit. 20x9 Black XD Hoss. 35/12.50/20 Nitto Trails. AFE Pro Guard 7. Retro's 6K HIDS. SOLD
2012 250. 20x9 Black XD Hoss, etc. etc. SOLD
Huffy 18" bike, sweet grips
tmillburg is offline
post #8 of 9 (permalink) Old 09-06-2009, 08:48 PM
Black Gold
tmillburg's Avatar
if u can get ahold of a peice of steel. block the rear by puttin the steel across the leaf springs and restin the bump stops on the steel. then the rear wont squat
TRACTION BARS TRACTION BARS TRACTION BARS
o and dont be one of them guys, bring a clevis
post #9 of 9 (permalink) Old 09-07-2009, 11:04 PM
lubeowner's Avatar
Weld the axle tubes to the center section, add traction bars, and block the rear end.
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
lubeowner is offline
