vgt stage 2 with 155s and a fuel system - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-30-2009, 04:45 AM Thread Starter
What do you guys think of a vgt stage-2 with 155s and a fuel system.I tow with my truck so i dont wanna run high egts i wanted to do 190s but are not sure on those.I have been reading other posts on here and those are gonna run hot while towing.So i tihnk 155s would be good i wanna keep a vgt turbo i like the spool up of them.What is the difference in a stage-2 vgt and a vgt ss turbo is it the samething or different.And what is the fuel system to go with fass or air dog.Eric tunes my truck so once its all in ill have him retune it again.Will i be able to make 500 to 500+ hp with that setup ill be happy with that. well let me know what you all think im just wondering what would be good for me for what i use my truck for.THanks
6.0 P/S Lariat FX4 CC/SB
37/12.50/20 nitto trail grappler 20'' black badlands
6inch lift
Mbrp Turbo Back Exhaust Cat Delete, Muffler Delete, 6Inch Tip,SCT Tuned By Eric,AFE Stage 2
Arp studs
Egr Junk deleted
Water Trans Egt Boost Fuel Phantom 2
Airdog 150, dozer diesel stage 2 RR, Fuel sump
stroker_1999 is offline
post #2 of 9 (permalink) Old 08-30-2009, 05:02 AM
Proud Sponsor
Abrannan19's Avatar
Re: vgt stage 2 with 155s and a fuel system
That's would be a good combo.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #3 of 9 (permalink) Old 08-30-2009, 05:36 AM
motoxracer42's Avatar
what size do you consider a stage 2. the main thing about high egts is keeping the turbo lit. if you go to big on the turbo than egts will suffer. sounds like a good setup but more info would make it easier to be sure.
06 crew cab
06 reg cab
motoxracer42 is offline
post #4 of 9 (permalink) Old 08-30-2009, 06:54 AM Thread Starter
64/88 turbo vgt is the vgt-ss the same as a stage-2 vgt
6inch lift
Arp studs
Egr Junk deleted
post #5 of 9 (permalink) Old 08-30-2009, 02:45 PM
than yea it should work pretty good.
06 crew cab
06 reg cab
post #6 of 9 (permalink) Old 08-30-2009, 03:00 PM
SamW's Avatar
sould work well for a daily driver. youll probly be right around 500
2006 F250 CCSB
6.
SamW is offline
post #7 of 9 (permalink) Old 08-30-2009, 03:34 PM
Redneck6.0L's Avatar
you'll be happy with that combo
2006 F-350 crew cab dually 4X4
225cc injectors, CRD twin turbo's
Fueled by Gibson's
2003 F-350 crew cab
[email protected]
Redneck6.0L is offline
post #8 of 9 (permalink) Old 08-30-2009, 05:00 PM
Stroker67's Avatar
im considering 155s and a 62 non vgt turbo with an airdog fuel system, should put me over 500 horses and still be able to tow.
Stroker67 is offline
post #9 of 9 (permalink) Old 08-30-2009, 06:43 PM
I had II stage 1 Hybrid turbo with 170 injectors and pulled everyday and I was really happy with the setup. Just switched over to II 62/70 and not really satisfied with its dead spots. dont know how much your towing but I pull about 8-10k everyday.
06 f250 supercab shortbed , MBRP turbo back straight piped, AEM intake, Innovative Tunes, First Coast Diesels EGR delete, II 62/70, Fass Fuel System 95/180, Swamps 170cc
surfdunn is offline
