Overheating while towing after coolant filter installed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 08-27-2009, 08:28 PM Thread Starter
SIC-E's Avatar
installed bypass coolant filter in my '04 E450. Only problem was lost o-rings in quick disconnect at firewall when replumbing for flush kit. fixed that. now it wants to get hot when towing my fiver. first time was in mountains so thought that was it. then did it again when only on flat terrain. no problems when not towing. never a problem prior to flush and filter install. Any ideas? thanx in advance guys.
2004 E450 Cutaway, 6.0L, quigley 4x4, ambul pkg., maxbrake cntrlr, curt 20k 5th whl. Future mods: 52" slpr, frame cover. Herd frt bmpr?
2003 E350, 7.3l, x-cargo
2003 JEEP, 17" Blk Moto Mtl 951's plugn 33" FC-II's, oops, not any more
1986 26' Seaway Northstar
2008 Montana Mtn'r 332PHT
1991 GMC Topkick, CAT
SIC-E is offline
post #2 of 13 (permalink) Old 08-27-2009, 09:19 PM
BUFF's Avatar
Re: Overheating while towing after coolant filter installed
How long has it been on? You may have air in the system.
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #3 of 13 (permalink) Old 08-29-2009, 02:30 AM Thread Starter
SIC-E's Avatar
that was my first thought and so rode with heat on full blast for quite some time. have driven 1500 miles or so since i did the work. gonna check to see if fan comes on when it warms up. dont recall if heard it or not. been a lil while since towed.
SIC-E is offline
post #4 of 13 (permalink) Old 08-29-2009, 06:36 PM
Harry Callahan
How did you plumb the coolant filter?
sniperonhigh is offline
post #5 of 13 (permalink) Old 08-31-2009, 05:04 PM
Diesel Enthusiast
MikeDually's Avatar
How many times have you changed have you changed the filter since you installed the kit? The first should be replaced ~1k, then the next about 2-5k, then you should be good for "awhile" on the third.
05 CC LB DRW
Studs, Full EGR Delete First Coast, SCT, MBRP 4" Straight, IssPros
MikeDually is offline
post #6 of 13 (permalink) Old 08-31-2009, 06:23 PM
Stroker67's Avatar
Depending on where you bought the kit at will tell you your filter change intervals, I've never read 1k after you install a kit. Just check out dieselsite.com that should give you some clue ab filter change intervals. Hope this helps
Stroker67 is offline
post #7 of 13 (permalink) Old 08-31-2009, 08:26 PM
RHCDIESEL's Avatar
did your fan kick on every 2 mins
2014 f250 4x4
Icon 2.5 stage 1 with adjustable track bar
Xd badlands black machined 18x9
Toyo 36x13x18 MT
2006 F250 FX4
175/30 warren inj
Madturbo stage 1
ARP headstuds
35/12.50/18 toyo M/T
428/871 PHP Dyno
RHCDIESEL is offline
post #8 of 13 (permalink) Old 08-31-2009, 08:35 PM
Stroker67's Avatar
where did you buy your kit from?
post #9 of 13 (permalink) Old 09-03-2009, 02:42 AM Thread Starter
SIC-E's Avatar
desielsite kit. haven't changed filter yet, but that should be immaterial, given that it is plumbed as a bypass filter. 1st overheat was 200 miles down the road. then fine till towed again. still haven't had the chance to check fan by towing. what can i do to check fan without towing?
SIC-E is offline
post #10 of 13 (permalink) Old 10-23-2009, 11:13 PM
Either a bad install, causing a leak or you blocked something or something else unrelated changed. I see no way the installation of a coolant filter could cause your truck to overheat. As you mentioned, it's a bypass filter.
In any event, good luck.
Al
FTG-05 is offline
