600 miles on fresh motor and already probs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 12-04-2014, 02:33 PM Thread Starter
Red face 600 miles on fresh motor and already probs
I pulled my motor on my truck and and brought it to my local diesel performance shop. i had him go through it and tell me what he thought needed to be done #8 was melted down and at that time i was on a budget and was hopping to get by with replacing just #8 and after some looking over a few things the shop decided that it was best to just do a complete rebuild. in the process i ended up having colt cams stage1 put in as well as elite diesel valve springs and rcd push rods.
after all was said and done and put back together 600 miles down the road i broke #7 intake rocker and #5 lifter, the machine shop said it wasn't their fault. they ended up fixing the valves a rocker arm and the lifter and went back through everything. my question is how in the hell is this not there fault and what would cause this? bad machine work? faulty lifter? any thoughts and opinions are welcome
Whiteout is offline
post #2 of 8 (permalink) Old 12-04-2014, 02:56 PM
matthewd11's Avatar
Re: 600 miles on fresh motor and already probs
It honestly sounds like valve geometry issues, i.e. pushrods too long. How much did they take off the heads? Did they machine the valves back to original installed height? Did they install new lifters??
matthewd11 is offline
post #3 of 8 (permalink) Old 12-04-2014, 03:05 PM
JGman141
Jgman141's Avatar
When doing a cam with no fly cutting its crucial that the valves are cut down with how much was taken off the head. Also I'm assuming you put in new lifters right?
Jgman141 is offline
post #4 of 8 (permalink) Old 12-04-2014, 03:08 PM
matthewd11's Avatar
lol mirror post ^^
post #5 of 8 (permalink) Old 12-04-2014, 03:15 PM
Big dumb redneck
6speedSD's Avatar
Garage
If you had them replace the lifters, then it's on them I'd say. If you had them reuse your old ones, then I would say that takes them out of the blame.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #6 of 8 (permalink) Old 12-04-2014, 03:25 PM
JGman141
Jgman141's Avatar
Originally Posted by matthewd11 View Post
lol mirror post ^^
Whoops I got alittle excited and just started writing my post lol, should have read yours first
Jgman141 is offline
post #7 of 8 (permalink) Old 12-04-2014, 04:17 PM
matthewd11's Avatar
Not that i was calling you out i just thought it was funny we both said the exact same thing.
post #8 of 8 (permalink) Old 12-08-2014, 12:50 AM
I put a colt cams stage 2 in mine. Ended up with .100 shorter pushrods because of length issue causing lifters to bottom out. Machine shop had taken too much off the deck of my block causing my problems.
jpott62 is offline
