24 volt Warn Winch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 08-25-2009, 02:48 PM Thread Starter
jvfurm's Avatar
24 volt Warn Winch
Does anyone know how to convert a 24 volt winch to a 12 volt winch??? I got this from a friend who was going to trash it and would like to put it on a old CJ-7 I built.
2007 Crew Cab Lariat
20" wheels with "Nittos"
4'" Turbo Back MBRP CAT Delete
S&B Intake
ZooDad Mod
Autometer Gauges
SCT X3 with custom tunes by Innovative Diesel
jvfurm is offline
post #2 of 15 (permalink) Old 08-25-2009, 03:21 PM
samdust's Avatar
Send a message via MSN to samdust
Re: 24 volt Warn Winch
just add a battery to your cj-7
2001 f-250,7.3,4x4,cc
CORNFED RANGER
samdust is offline
post #3 of 15 (permalink) Old 08-25-2009, 11:28 PM
I believe that you have to replace the motor. You may also need to replace the solenoids. Check some of the rockcrawling sites they have lots of information on Warn winches. There are aftermarket companies that sell replacement motors with more hp for less than the Warn ones.
kwissman is offline
post #4 of 15 (permalink) Old 08-26-2009, 02:58 AM Thread Starter
jvfurm's Avatar
With what SAMDUST said about adding another battery, how would it be wired up so it will not effect the 12v system on the rest of the vehicle?
I will defiantly check those sites to see what I can dig up. If it is worth the cost of replacing the motor and solenoids great, if not hello e-bay!!!
S&B Intake
ZooDad Mod
Autometer Gauges
jvfurm is offline
post #5 of 15 (permalink) Old 08-28-2009, 03:02 PM
squeak12's Avatar
I would imagine that you would need a 24V charging system, then run a stepdown to 12V for everything else. Not really that effective at all. The only other choice that I know of would be to have a bank of batteries for the winch alone.
I don't know anything about 24V winches, so there may be an easier method. I would think converting it to 12V would be the most cost effective, though.
2001 F-250 Crew Cab 4x4
squeak12 is offline
post #6 of 15 (permalink) Old 08-28-2009, 03:15 PM
PSN Mega Miler
crowz's Avatar
Didnt find anything simple but I did find something I think will help.
Contact these folks : DB Electrical Starter-Alternator
Seems someone on another site had a similar project and they help them out on it.
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #7 of 15 (permalink) Old 08-28-2009, 03:58 PM Thread Starter
jvfurm's Avatar
Thanks, I checked their site and it seems that the winch motors are not that expensive at all. I will be contacting them.
Thanks again for all of your help.
S&B Intake
ZooDad Mod
Autometer Gauges
jvfurm is offline
post #8 of 15 (permalink) Old 08-29-2009, 09:09 PM
You'll have to change the solenoids and I think the motor just has to be reconfigured, change its windings from series to parallel.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #9 of 15 (permalink) Old 08-29-2009, 09:23 PM
I have the same problem with a 24v winch that i have. Its not a warn but I contacted a few electric motor shops and they told me they could not convert it to 12v. But if you run two batteries in series you can get the 24v from the + of one to the - of the other. from my understanding you can still pull 12v to run the truck and charge with a 12v altenator
99 powerstroke reg cab 6 speed 4in lift t+s 6 position chip 5in exhaust k+n intake and exhaust brake
post #10 of 15 (permalink) Old 08-30-2009, 06:42 PM
No, you can't hook two batteries in series and parallel at the same time, that would cause a direct short.
