Transmission Fluid - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 20 (permalink) Old 12-02-2014, 04:11 PM Thread Starter
Transmission Fluid
What's the general consensus on transmission fluid I know stock they use the Mercon however I'm an avid amsoil supporter. Does anyone have any insight on whats best...
syndicate speed shop is offline
post #2 of 20 (permalink) Old 12-02-2014, 04:15 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Transmission Fluid
If it's the 5r, stay with Mercron LP or SP (I forget which is the latter)
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 20 (permalink) Old 12-03-2014, 08:23 PM
IIvonnyII's Avatar
i believe SP is the one you want to run with the 5r110. they are rather finicky with oils.
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #4 of 20 (permalink) Old 12-03-2014, 11:16 PM
matthewd11's Avatar
LV is fine to use also. SP and LV are interchangeable. IIRC i think LV actually replaced SP.
matthewd11 is offline
post #5 of 20 (permalink) Old 12-03-2014, 11:26 PM
Administrator
Zmann's Avatar
Ford states either is ok and intermixable
I run LV like the 08+ up trucks because between the fluid and filter change the service interval was spaced out substantially
SP is still available but it is mainly for Manual transmissions that can't use the LV
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 20 (permalink) Old 12-13-2014, 03:43 PM
mt454casull's Avatar
id go with either redline or amsoil.
mt454casull is offline
post #7 of 20 (permalink) Old 12-13-2014, 06:33 PM
Administrator
Zmann's Avatar
why ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 20 (permalink) Old 12-14-2014, 01:07 AM
strokin6L's Avatar
There's guys running amsoil with no issues. I run the cheap carquest brand mercon/dexron trans fluid. Been running it for probably over 5 years with zero issues. I know that a lot of guys run regular mercon/dexron ATF fluid with a built trans.
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
strokin6L is offline
post #9 of 20 (permalink) Old 12-14-2014, 02:05 AM
Administrator
Zmann's Avatar
are you sure carquest has an fluid approved for use where Mercon LV or SP is specified ?
Valvoline does but it's about the same price as the Motorcraft Mercon lv or sp and has only been approved for a few years i still have bottles that do not have approved listed on them
i actually called Valvoline because their website stated approved but the bottles didn't ( i still had a warranty to worry about not to mention a $4000 trany
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #10 of 20 (permalink) Old 12-16-2014, 09:17 PM
Napadan's Avatar
Just checked my latest bottle of Valvoline Maxlife ATF (I work at NAPA) and they have Mercon LV right on the front of the bottles now Zmann. I changed out mine when I got it about a year ago with this and everything seems to be going smoothly.
05 F250 SCLB. 75k Water filter, blue spring upgrade,Magnaflow 4" turbo back system w/muffler and SCT tuner with custom tunes by Drew.
Napadan is offline
