Looking to upgrade Batteries... Suggestions? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 12-01-2014, 11:35 PM Thread Starter
Astroc2002's Avatar
Garage
Question Looking to upgrade Batteries... Suggestions?
Ok.. my 05 F250 6.0's stock 110amp alternator has failed for the third time straight. It was replaced last in 2012 and twice in 2011. Now my question is which company to get a better pair of batteries. I know there's clashing input of differences between Odyssey and Optima, but I wanted to get advice from you guys on here. Tried to search for which of the two evils is better than the other. Please feel to voice your inputs.
Also alternator will be upgraded to either a 190 amp or 250 amp and running 0/2 gauge positive wires from batteries as one company (annymous) recommended and said that there was no need to upgrade the grounds to 0/2 gauge wires due to the 6.0 already having two grounding points.
2005 F250 4x4 6.0L Powerstroke
Mods: MBRP 5" TB T409 Exhaust with Stock Catalytic Converter Pioneer AVH-4100NEX w/iPod & Android Connections Banks Intercooler System(Custom Coated) Deka 0/2 Gauge Battery Harness DC Power Red 190a HD Alternator Rancho RS9000XL Shocks Volant PowerCore Intake CCV Filter Kit Powerstop Z36 Calipers/Pads/Rotors
Astroc2002 is offline
post #2 of 27 (permalink) Old 12-02-2014, 02:18 AM
Re: Looking to upgrade Batteries... Suggestions?
I use diehard platnium AGM.
lenzhotrod is offline
post #3 of 27 (permalink) Old 12-02-2014, 09:45 AM
Work&Play's Avatar
X2
I have had mine for 3 years and love them.
They are just pricey.
Andy 2007 4X4 F350,6.0 PSD, Lariat, CC, DRW, 9' Knapheide body, stainless steel ladder rack, SCT with custom tunes, Banks turbo back, ARP's, ITP RR, Airdog II, Powermax with Billet Wheel, Firestone air bags, Autometer gauges( pyro,fuel pres,water temp,boost,trans temp), CCV mod.
Work&Play is offline
post #4 of 27 (permalink) Old 12-02-2014, 02:12 PM
Wheelhop's Avatar
X3
I installed the duracell AGMs last month. The AGM is worth the extra cost.
If you do a search, you'll find that a number of guy's are disappointed with the Optimas. It sounds like their quality has diminished in the last few years.
Wheelhop is offline
post #5 of 27 (permalink) Old 12-02-2014, 03:56 PM Thread Starter
Astroc2002's Avatar
Garage
Smile Re: Looking to upgrade Batteries... Suggestions?
Well I went ahead and ordered two Odyssey Extreme 65-PC1750T Batteries and a Deka 116" Double Gauge (in otherwords 2/0 Gauge). The truck was initially was running two Motorcraft 65-BXT-850 Batteries on stock harness with the stock 110amp Alternator. Well the Odyssey Batteries will deffinately speed up warm up and start up process, now the 190amp Upgrade Alternator is a different story which explains the upgraded harness. I'm planning on getting an amplifier to go with the speaker upgrade for my truck, its a 600watt Amplifier that demands between 11Volts to 16Volts. Plus I wanted a little extra Amps when stereo is done to accomodate Electric Fans and Off-Road Lights later on down the line.
post #6 of 27 (permalink) Old 12-13-2014, 03:48 PM
mt454casull's Avatar
I have been running costco batteries in my truck. They have a ridiculously good warranty and I have had them in a cold environment in Montana and Alaska for the last 5 years and they are still working great with no hassles. I will put another set of them in my truck when these start wearing out.
2004 Ford F350. 373 rear end. Amsoil, or Redline in everything except motor Rotella T-6. Egr delete, ARP studs, coolant bypass, oil bypass. Add Tcw3 to my fuel. 4 in turbo back, and AFE cold air. Sct x3 with PHP tunes and FICM Atlas 40 tune.
mt454casull is offline
post #7 of 27 (permalink) Old 12-13-2014, 04:47 PM
scott2001's Avatar
I just buy the highest cranking amp batteries I can find. I really don't care if there pink with green dots
last set I got was from napa I think or abbies I think his was like power cell or something
2008 got a new flex pipe installed. S-b intake, 4in dp back exhaust, gear head tunes All deletes done now.
flow pro hot pipe. CCV mode.
2013 dodge charger
scott2001 is offline
post #8 of 27 (permalink) Old 12-14-2014, 03:42 AM
Fuel it up again Dummy
Mhatlen's Avatar
Send a message via MSN to Mhatlen
Im one of those guys that no longer will buy Optima batteries.
I have used them for at least 10 years but the quality is not there today. Still have a red top in wife's Tahoe that's 6 years old now. Still strong too, but it is a American made one.
I bought two yellow tops for my truck and one went bad in a year. Had it replaced and 6 months later other one failed on me.
I replaced them with Die Hard Platinum AGM's and I never saw my starter turn so fast.
That's when I realized how weak the Optima's really were.
You can't go wrong with the Die Hards or the Odyssey line of AGM batteries. Will cost you a few more bucks but odds are they are going to last 6-7 years unlike standard acid lead plate batteries.
Happy Shopping.
2006 F250 Lariat CCSB 4X4, ARP Studs, O-Ringed heads Fass 125, Cat EC-1, IPR coolant filter, SCT Tuner w/PHP custom tow tune, Atlas40, Updated Turbo lines/stc/standpipes/D-plugs No EGR, DC Power 270 amp, 4" SS exhaust w/Corsa, Amp Steps, Die Hard AGM Platinums, Icon coils Carli/Deaver leafs 7" of lift, All on Fatty Daddy Toyo MT 38/15.50/18
Mhatlen is offline
post #9 of 27 (permalink) Old 12-14-2014, 03:50 AM
My Costco batts are 6 yrs old and still going....
97 250 7.3 Eaton VMP TVS, IDI performance T4 mount, S369SXE, my B code 350/200- my tunes- honey badger SR, Efuel, 5" SKY RSK TTB, BMW M3 seats, Toyo M/T
54 GMC 453T
45 Chevy 451 diesel
51 Mack A51T
1916 Federal 1 1/2T
boostedretard is offline
post #10 of 27 (permalink) Old 12-14-2014, 04:35 AM
Administrator
Zmann's Avatar
i haven't seen any Odyssey battery complaints but i don't know anyone with them in our type of use now Optima won't get my money hencho en mexico = no bueno
i use AGM platinum from Auto Zone probably made in mexico also
like mentioned it's about CCA's and warranty duration / coverage
DTR's Donation page
RIP DTR Ron
Zmann is offline
