500 rwhp? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-20-2009, 06:20 AM Thread Starter
6. NO LEAKER
SKINNER's Avatar
500 rwhp?
ok Im shootin for 480-500 rwhp.
what else would I need to do so?
SCT live wire (ID tunes)
snow performance stage 1 water meth
FASS 150
EGR delete
AFE stage 1
Aurora-V 3000
SKINNER is offline
post #2 of 9 (permalink) Old 08-20-2009, 06:39 AM
ADubDiesel's Avatar
Re: 500 rwhp?
I'd stay away from meth and ATS. 6.0 guys will chime in on what else you need. Might want to add some studs too.
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #3 of 9 (permalink) Old 08-20-2009, 12:47 PM
FNG
Dave's Avatar
Re: 500 rwhp?
FASS 150
EGR delete
AFE stage 1
Aurora-V 3000
Skip the water meth unless you are gonna use it for cooling only
Add studs to the list.
Theres 2 ways to go about it.
1 would be nitrous
The way I will be doing it is, studs, EGR delete, 190's Airdog and regulated return and Elite or Industrial VGT SS
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #4 of 9 (permalink) Old 08-20-2009, 12:57 PM
The Fireman
big_stroker's Avatar
Re: 500 rwhp?
Studs, EGR delete, and good tunes will put ya around 450hp or so.
Add a good turbo and a small set of injectors and you are 500 easy.
big_stroker is offline
post #5 of 9 (permalink) Old 08-20-2009, 01:36 PM
motoxracer42's Avatar
Re: 500 rwhp?
studs egr delete and a good set of 190s with the stock turbo will put you over 500. eric has a couple trucks running that setup. do you want to make that with or without any spray or water/meth
06 crew cab
06 reg cab
motoxracer42 is offline
post #6 of 9 (permalink) Old 08-20-2009, 04:01 PM
Stroker67's Avatar
Re: 500 rwhp?
155s, 62 turbo, fuel system, studs, egr delete and tunes, you should be over 500
Stroker67 is offline
post #7 of 9 (permalink) Old 08-20-2009, 04:20 PM
SamW's Avatar
Re: 500 rwhp?
155s and a modded vgt would put you around there and very streetable. I cant remember the guys name but someone over on the org had 508 hp and 812 torque with 155s and a 64.
2006 F250 CCSB
6.
SamW is offline
post #8 of 9 (permalink) Old 08-20-2009, 04:21 PM
Stroker67's Avatar
Re: 500 rwhp?
155s will still give you the ability to tow heavy loads, the set up i told you is what im planning on going with one day, and still be able to tow my grandmothers 5th wheel camper. If your not going to tow, then go 190s
post #9 of 9 (permalink) Old 08-20-2009, 10:20 PM Thread Starter
6. NO LEAKER
SKINNER's Avatar
Re: 500 rwhp?
I would like to do studs and sticks but not enough money right now.
I already have egr delete and a fuel system. getting a live wire next week.
Im gonna talk to my tech and see what he would charge me for studs.
SKINNER is offline
