Fuel System Upgrades for Stock Injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 35 (permalink) Old 08-20-2009, 06:09 AM Thread Starter
Diesel Addict
BilletGarage's Avatar
Recommendations? Regulated Return? Fass Pump/Filter? Airdog II? Mods are in my sig. Thanks in advance!
BilletGarage is offline
post #2 of 35 (permalink) Old 08-20-2009, 02:29 PM
iracemx6's Avatar
Re: Fuel System Upgrades for Stock Injectors
I thought Adam answered those questions in the other post
Just get you a Fass or Air Dog and you are good to go even if you upgrade injectors.
A regulated return is not necessary.
2003 F-250 CC FX-4...4x4
Tuned by INNOVATIVE
Industrial Injection Turbo
200cc sticks by CASSERLY
Zex-Nos
12.73...1/4 on 190's
iracemx6 is offline
post #3 of 35 (permalink) Old 08-20-2009, 02:46 PM Thread Starter
Diesel Addict
Yeah he did, and I value Adam's opinion and yours for that matter but I'm interested in hearing what other people have to say as well.
post #4 of 35 (permalink) Old 08-20-2009, 02:56 PM
Proud Sponsor
Abrannan19's Avatar
,I wont repost.
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #5 of 35 (permalink) Old 08-20-2009, 03:05 PM
iracemx6's Avatar
They are gonna just tell you to listen to me!!
A regulated return would be of benefit if you were going with HUGE injectors and needed volume to feed them,but the average person isn't gonna go larger than 190's so it's isn't necessary.
Get a good pump and you will be fine......it's that easy.
Tuned by INNOVATIVE
Zex-Nos
iracemx6 is offline
post #6 of 35 (permalink) Old 08-20-2009, 03:43 PM
Proud Sponsor
Abrannan19's Avatar
David is right, if you just feel the need/want to upgrade line sizes you can do so, there are parts that will allow you to address from the front of the fuel bowl to the fron of the heads and another kit that will address fuel flowing thru the back of the heads. You can do all of this without having another regulator.
With that said, you can make plenty of powa with the stock fuel lines from the secondary fuel bowl, it has been done, 693 with 200's, FASS and spray.
Adam Brannan
Email
post #7 of 35 (permalink) Old 08-20-2009, 06:10 PM
SamW's Avatar
thats what I have, well not the 200s and spray but the upgraded lines from the bowl to front of the heads and the crossover line between the back of the heads with a fass 150 180 feeding it. its internally regulated, no need for a second one and holds 55 psi easily. as long as you keep the fuel pressure up above 45-50 psi then you should be good to run bigger injectors. you just dont want to starve the injector of fuel and a truck with just a hot tune can drop the fuel pressure to 5-10 psi on a hard pull if the truck is fed by the factory hfcm.
2006 F250 CCSB
6.
SamW is offline
post #8 of 35 (permalink) Old 08-20-2009, 06:13 PM
Stroker67's Avatar
well this thread is full of good info, i wont be worrying about getting a regulated return, sounds like the airdogg II im wanting will work out perfectly
Stroker67 is offline
post #9 of 35 (permalink) Old 08-20-2009, 07:10 PM
iracemx6's Avatar
There ya go!!
Just trying to save you a headache and alot of cash my man.
Tuned by INNOVATIVE
Zex-Nos
iracemx6 is offline
post #10 of 35 (permalink) Old 08-20-2009, 07:40 PM
Kubota Service Tech
HarleyF250Guy's Avatar
I am still on stock injectors. I currently am running a Trusted Performance fuel system. I have bigger lines that run from the 2nd fuel bowl to the heads and the crossover line that connects the back of the heads. I can tell you right now.....once these were installed the truck seemed to idle alot smoother and not as loud. Take it for what its worth........
05' Harley F250
8'' Lift on 38's
AMP Power Steps
Edge Insight
Silverline 4'' Turbo Back Exhaust
Airaid Intake
ARP Studs
FCDP EGR Delete
Trusted Performance Stage 1 & 2 Fuel System
SCT X3 w/ Innovative Extreme Race
HarleyF250Guy is offline
