pyrometer gauge - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 08-20-2009, 04:50 AM Thread Starter
get busy livin
530farmboy's Avatar
Lightbulb pyrometer gauge
Hey im runnin a 6.0 with sct on extreme race and i bought a pryo gauge but do you have to take the manifold off to put drill and tap it or can you do it with out pulling it?
2006 Extra cab 4x4 her name is Jesabell
straight pipe 6" tip
arp studs, sct x2 with custom innovative tunes nothin special
530farmboy is offline
post #2 of 17 (permalink) Old 08-20-2009, 04:53 AM
Don't EFN worry about it
Aljay's Avatar
Re: pyrometer gauge
You can do it with the mani. on the truck just drill it on the thin side! I used a 1/2" air drill ,I had the butt of it over in the frame it can be done I have done a chit pot of them.
Tuned by T Wildman
Aljay is offline
post #3 of 17 (permalink) Old 08-20-2009, 05:15 AM
Banned
Re: pyrometer gauge
I use a 1/8'' and work up to 1/2'' .
FRUITBOY is offline
post #4 of 17 (permalink) Old 08-20-2009, 03:42 PM
06powerstroke's Avatar
Re: pyrometer gauge
I pulled my manifold out to do it. It wasn't that bad and that way I knew for sure that no metal went through the turbo. I was also sure that I got a good, clean, strait hole drilled, and I could tap it nicely...
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #5 of 17 (permalink) Old 08-23-2009, 12:59 AM
Wondering what if
123rday68's Avatar
Re: pyrometer gauge
I left my manifold on the truck but with a friends help had both a magnet and the shop vac going to collect the metal shavings. I removed the fender well on the passenger side to install it. Seemed like the most amount of room.
'07 F350 3" lvl, fndrs trmd, 37" M16's
Ultra lites ECT,EGT,EOT Oil and top fuel billet caps
banjo bolts drilled cautiously, ccv, zoodad mods Dieselsite coolant filter
SCT SF3 can tunes
Mike's Diesel Performance
KT Performance
DieselPowerProducts.com
Dieselsite
123rday68 is offline
post #6 of 17 (permalink) Old 08-24-2009, 11:44 PM
Re: pyrometer gauge
You dont have to pull a fender you should drill and tap it on the drivers side rear cylinder Aka cylinder 8. I just worked my way up to 1/8 inch and dipped my bits in grease to collect the shavings and clean it every so many seconds while also adding grease. You dont have to drop a manifold to get it done...but to each their own.
boyonblue52 is offline
post #7 of 17 (permalink) Old 08-25-2009, 02:48 AM
SamW's Avatar
Re: pyrometer gauge
work your way up from 1/8th. i wouldnt grease it, more shavings will fall out and get a small magnet to stick up there after you tap it, then use a shop vac and suction out the rest. its not that bad
2006 F250 CCSB
6.
SamW is offline
post #8 of 17 (permalink) Old 08-25-2009, 03:09 AM
it's an 02 05 08
turbodiesel_02's Avatar
Re: pyrometer gauge
I did it on the bottom of the driver side maniforld and worked my way up with an air drill and stuck a magnet in there so often and shop vac'd it out,piece of cake
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #9 of 17 (permalink) Old 08-30-2009, 12:12 AM
motoxracer42's Avatar
Re: pyrometer gauge
i just left the truck running and started with a small drill and worked my way up slowly. it wont hurt anything ive done it on plenty of trucks.
06 crew cab
06 reg cab
motoxracer42 is offline
post #10 of 17 (permalink) Old 08-30-2009, 12:43 AM
Wondering what if
123rday68's Avatar
Re: pyrometer gauge
I forgot to mention besides the other I stated, I too left truck running.
SCT SF3 can tunes
KT Performance
Dieselsite
