Need non vgt turbo help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-19-2014, 01:00 AM Thread Starter
2004 6.0 6 speed will be getting a set of warrens 190/75 and im looking to get a non vgt turbo for it, ill be making my own piping for it so no worries there. I have a s300 setting in my shop but im not sure if that would have enough stream.Eric will be tuning it from Innovative Diesel. i dont tow much just my race car every couple months but i would like to get a quick spooling low heat turbo
stroked21 is offline
post #2 of 11 (permalink) Old 11-19-2014, 01:15 AM
JGman141
Jgman141's Avatar
Re: Need non vgt turbo help
That's going to be a little tuff to do, 75% nozzles are not going to be very towing friendly. Are you going to be using a t4 housing?
Jgman141 is offline
post #3 of 11 (permalink) Old 11-19-2014, 01:48 AM Thread Starter
t4/t3 housing doesn't matter to me, my buddy has a 7.3 i know a little bit bigger motor but hes got 230/80 with an s300 and tows everybody 8k plus and his egt are low so im thinking being a little smaller motor and towing less then 4.5k i should be fine
post #4 of 11 (permalink) Old 11-19-2014, 02:12 AM
JGman141
Jgman141's Avatar
I would look into the s364 with the FMW, that should spool up quick enought with the right size turbine wheel and housing. I'd look into the 71mm wheel with a .91 divided housing.
Jgman141 is offline
post #5 of 11 (permalink) Old 11-19-2014, 03:38 PM Thread Starter
Ok thanks, I just looked into this s300 I have and it's got a 66mm wheel with an 91. I'm thinking that it would work if I got a wicked wheel or a fast spool wheel in it
post #6 of 11 (permalink) Old 11-19-2014, 10:19 PM
JGman141
Jgman141's Avatar
If you do get a billet wheel I'd have the turbo balanced
Jgman141 is offline
post #7 of 11 (permalink) Old 11-19-2014, 11:33 PM Thread Starter
Ya I would, do you think that turbo would work well with that size of injectors? An woul it be fast spooling
post #8 of 11 (permalink) Old 11-20-2014, 12:42 AM
JGman141
Jgman141's Avatar
The only s366 I saw on a 6.0 spooled fairly decent, he was towing my truck on a goose trailer and 350/100 on a tow tune. Obviously there was a lot of fuel pulled out but it stay really cool for what it was.
Jgman141 is offline
post #9 of 11 (permalink) Old 11-20-2014, 02:27 PM Thread Starter
Ok, well thanks I think I'm going to try the s300 out I don't see why not the turbos are fairly close and I might be able to save a little bit of money, my only other question is do you think I shoul get a bigger hpop or will the stock one be fine?
post #10 of 11 (permalink) Old 11-20-2014, 03:17 PM
JGman141
Jgman141's Avatar
Stock hpop should be fine with 190/75s
Jgman141 is offline
