Suggestions on programmers - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 11-12-2014, 09:25 PM Thread Starter
joemx611's Avatar
I got myself a 6.0 for a work truck and I just want to delete the emissions and prolly throw a set of head studs in.. I guess my first question is do I even need a programmer to do these things? I know emissions weren't as big of an ordeal when these trucks were produced like they are on newer ones. My second question would be, if I do need a programmer what is a suggested one? I have a 6.4 with a mini max and love it but don't wanna spend that kind of money on the work truck if I don't have too.. I more or less just want something that will work I'm not hard pressed for big hp or torq numbers.. All in all I just want to make this truck last and dismiss all the bs problems, truck is bone stock now with 120k any suggestions are appreciated thanks
08 6.4 king ranch 4 door long bed, play truck with all the goods
05 6.0 single cab flatbed, bullet proofed work truck
joemx611 is offline
post #2 of 14 (permalink) Old 11-12-2014, 09:52 PM
JGman141
Jgman141's Avatar
Re: Suggestions on programmers
you can delete the egr and do studs without a tuner but your check engine light will be on. As for a tuner sct is the only way to go with the 6.0.
Jgman141 is offline
post #3 of 14 (permalink) Old 11-12-2014, 11:31 PM
I would flush the coolant and put coolant filter on it.
Stroker56 is offline
post #4 of 14 (permalink) Old 11-12-2014, 11:47 PM
As stated, with an 06 and no tuner, you will get a CEL if you delete the EGR. 03-04's usually don't, but the later models do.
SCT is a good route if you are looking for a cost friendly programmer that holds custom tunes. We carry them and can get you setup with EGR delete tunes to go with it. Check it out HERE.
post #5 of 14 (permalink) Old 11-13-2014, 09:56 PM Thread Starter
joemx611's Avatar
Thanks guys, I'm thinking about just keeping it basic with exhaust intake egr delete and possible studs and possibly a programmer. I just had a hpfp and a couple injectors put in and it seems to be ok now but I wanna eliminate anymore issues before I get stranded on the side of the road again
joemx611 is offline
post #6 of 14 (permalink) Old 12-01-2014, 10:44 PM Thread Starter
joemx611's Avatar
Am I going to need custom tunes on this SCT programmer for the dpf delete?
joemx611 is offline
post #7 of 14 (permalink) Old 12-01-2014, 10:48 PM
IIvonnyII's Avatar
joemx611, you will not need custom tunes with the EGR delete, you can turn the valve off with the programmer.
BUT I would still highly recommend custom tunes.
talk to Matt @gearhead. Vivian @ quicktricks.
Admin of BCCR
2007 f-350 CC/SB Lariat --SOLD--
2006 F-350 CC/SB Harley Davidson
- 205/100s
- Custom twin superduty pump fuel system W/ RR
- BW S366
- 4" exhaust to dual 5" tips
- air raid CAI
- 80k miles
- levelled, 35s
- Bulletproofed
- Gearhead tuning
IIvonnyII is offline
post #8 of 14 (permalink) Old 12-03-2014, 12:16 PM Thread Starter
joemx611's Avatar
Ok thanks guys! One more thing, I've noticed that the truck starts fine cold but now and again when it's warm it takes me a couple tries to get it fired back up, would that be the glow plug relay?
joemx611 is offline
post #9 of 14 (permalink) Old 12-03-2014, 01:33 PM
JGman141
Jgman141's Avatar
Hpo leak
Jgman141 is offline
post #10 of 14 (permalink) Old 12-03-2014, 03:07 PM Thread Starter
joemx611's Avatar
Wat is hpo?
joemx611 is offline
