Heavy Duty Clutch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-10-2014, 11:03 PM Thread Starter
YZ250F12154's Avatar
Heavy Duty Clutch
I am biting the bullet and ordering a South Bend Dual Disc clutch, I'm just wondering if I should be looking for an upgrade for the hydraulics too. From what I have heard, Ford's stock clutch hydraulic components are pretty durable, but a friend of mine said that from my description it sounds like I need new hydraulic components. My clutch slips under anything more than normal acceleration, and I have also had the pedal stay on the floor after hard acceleration through a couple of gears. I know the clutch is slipping due to the performance tune I have in the truck. Does it sound like I need hydraulic components? Or does it just sound like a new clutch will do the trick? Thanks!
YZ250F12154 is offline
post #2 of 3 (permalink) Old 11-15-2014, 01:15 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Heavy Duty Clutch
Stock hydraulics are sub par at best. And unless something has changed in the past couple years since I owned a truck with a ZF, there really isn't an upgrade to the stock stuff. There is only so much you can expect from a plastic hydraulic system.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 3 (permalink) Old 11-22-2014, 01:33 AM
Having the same debate here. My 05 is doing the same, since the problem started after a tuner it would only make sense to me that my clutch is slipping. I am going to change the clutch first and eliminate that "what if", just gotta figure out which clutch to go with. any info there would be appreciated.
05 F250, 6Spd, 4" turbo back Magnaflow Duals, No cat. No muffler, Egr delete, Intake, SCT X4
bronco3512 is offline
