Gauges - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-16-2009, 09:47 PM Thread Starter
Talking Gauges
So i just went and picked up my four pillar and gauges....i know how to hook up the pyro and boost but the high pressure oil and fuel pressure i have noooo idea. Can anyone help? pictures or anything would be sweet. Thanks!!
boyonblue52 is offline
post #2 of 4 (permalink) Old 08-16-2009, 11:22 PM
Brentos's Avatar
Re: Gauges
hpop plugs into the icp sensor.
fuel pressure assuming you have stock fuel system goes in the test port on the front drivers side of the fuel bowl. if you do not have the adapter you will have to get one like the one listed on itp's website
Brentos is offline
post #3 of 4 (permalink) Old 08-16-2009, 11:29 PM
Stroker67's Avatar
Re: Gauges
Heres the adapter kit from dieselmanor.com
http://www.dieselmanor.com/dm_products/fittings.asp
Hope this helps, if you dont want to put it in the test port, then you can get billit caps that you can use for the fuel pressure and if you decide one day for oil temp gauge, youll have a place to to do that gauge as well.
Stroker67 is offline
post #4 of 4 (permalink) Old 08-17-2009, 01:59 AM Thread Starter
Re: Gauges
I believe i have all the adapters and everything i need. Walley at F.T.E DIESEL doesn't mess around. This sounds like a much easier process now . I was thinking i would have to tap into a line or somethin haha
