want to put a standard dually bed on my 2005 cab/chassis - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-05-2014, 07:58 PM Thread Starter
how hard will it be to put a regular dually bed on my 2005 cab and chassis dually. what will i need to do so that it will not have a gap between the cab and bed??
javi107 is offline
post #2 of 8 (permalink) Old 11-05-2014, 10:45 PM
Powerstroke n00b
Justincredible's Avatar
Re: want to put a standard dually bed on my 2005 cab/chassis
its not that that you have to worry about. frame rails are different widths apart. so youll have to figure out a way to mount it. and youll have to have different height mounts because bed isnt flat on the bottom.
1997 F-250 zf6, t-500 Hpop, Baby swamps, Beans D66 w/ 1.0, hydra, 6637 CAI, 6" exhaust. Kingpin D60
Boost, Oil pressure, HPOP Pressure, Water temp, Oil temp, Trans temp and EGT, fuel pressure
soon efuel and 3" plenums and intercooler.
Justincredible is offline
post #3 of 8 (permalink) Old 11-06-2014, 03:19 PM
Big dumb redneck
6speedSD's Avatar
Garage
Pretty sure he will still have that gap between cab/bed.(or is that only with xcab/crewcab?) But yes, frame rails aren't the same width. Cab/chassis rails are narrower, as is the axle I think. There is one locally that did exactly this...rear tires tuck way inside the fenders...just looks goofy to me, but I'm OCD about that stuff.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #4 of 8 (permalink) Old 11-06-2014, 08:10 PM Thread Starter
i have the alcoa 22.5 wheels on it so they wont stick in. i can cut and weld the bed on there but i just dont like that it will have a gap. i think im just going to have to put a flat bed back on.
javi107 is offline
post #5 of 8 (permalink) Old 11-06-2014, 08:33 PM
Big dumb redneck
6speedSD's Avatar
Garage
I know on some cab/chassis trucks there is a gap. Not sure if there is on a reg cab or not. Hopefully someone with experience will chime in here soon. A little google searching should get you the difference in widths between a chassis axle and reg DRW axle.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #6 of 8 (permalink) Old 11-06-2014, 10:30 PM Thread Starter
yea ive been doing alot of research and looks like i will be having to do alot of cutting and welding in order to not have that gap. or maybe put stacks to cover the gap?? lol
javi107 is offline
post #7 of 8 (permalink) Old 11-07-2014, 12:33 AM
badazzharley's Avatar
There have been several afremarket companies that made F550 pickups. Fontaine and Classic Coach were two of them. They made a fiberglass spacer that bolted on the bed to fill the gap. I have seen them for sale on ebay. Do your homework and I'm sure you can find one.
badazzharley is offline
post #8 of 8 (permalink) Old 11-07-2014, 05:01 AM
Here's one of my trucks with stacks taking up the space between the bed and cab.
