2004 f250 6.0 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-01-2014, 09:06 PM Thread Starter
2004 f250 6.0
I have a f250 2004 6.0 it is still stock except for EGR delete. it has 250000 miles on it and I would to to add somethings that would make it have a little more power and better mileage and help me keep another 250000. what suggestions do you guys have?
total chaos is offline
post #2 of 5 (permalink) Old 11-01-2014, 10:12 PM
JGman141
Jgman141's Avatar
Re: 2004 f250 6.0
Sct tuner with custom tunes
Jgman141 is offline
post #3 of 5 (permalink) Old 11-02-2014, 03:40 PM
Re: 2004 f250 6.0
I had the same setup, totally stock up until I threw a lifter @225k. Only thing I had was a coolant filter which was working as intended. In hind sight, I would have had an oil analysis done to check for metal, it may or may not have saved my engine.
artwhitting is offline
post #4 of 5 (permalink) Old 11-02-2014, 10:51 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: 2004 f250 6.0
With 250k miles, I think I'd spend the money on replacing worn out parts instead of adding power. You said you want it to last another 250k...just adding power to it won't make it last.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #5 of 5 (permalink) Old 11-10-2014, 04:25 AM
MT KingRanch's Avatar
Re: 2004 f250 6.0
Dittos.
04.5 F-350 KR. ARP studs, Sinister Wrapped Y-Pipes and R.R. Fuel System,Atlas40 FICM, DC Power 190Alternator,BPD remote oil cooler&updates,BPD Water Pump/7.3 Fan Clutch, EGR Cooler delete,DieselSite Coolant Filter, AEM Brute Force HD intake, 4" Flow-Master,2.5" Level Kit/33" Toyo AT II's, D.D. Solenoid Mod, CCV Delete. SCT X4. KC Stage 1.5 Turbo.
MT KingRanch is offline
