New Intake Set-Up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 08-11-2009, 01:33 PM Thread Starter
AllYourBaseAreBelongToUs
imelmo's Avatar
New Intake Set-Up
Re-did the intake on my Procharger set-up last night. As you can see from this first pic, it was drawing in some really hot air being stuck behind the radiator and on top of the hot-side intercooler pipe. When I'd get done driving some times you couldn't even put your hand on the filter. Additionally, the mass air meter wasn't hooked up:
So after talking with David at Diesel Innovations, we decided to cut out a section of the radiator support and route the intake thru it and get the filter just behind the grill. I just used a grinder to cut out the section that needed to be removed and used some vinyl clip on trim on the edges (that we use on the lifeboats). To do it I also had to drop the a/c core down. I just made some brackets and attached the stock core supports to them, then dropped the power steering cooler down a little. While doing this I also noticed one of the trans cooler lines had a nice twist in it and was almost completely kinked. I don't really know how my trans never got hot. After that, I soldered some extensions onto the mass air meter and ran it along the piece behind the grill to the filter. I just cut out the mass air meter mount from the stock piece. I took a quick test drive last night but didn't get on it or anything. Cruising at 80mph I saw a 50-70deg drop in egt's, lol. So I'd say it's working. I'll have some better numbers today. Also, my trans was running about 15-20deg cooler with the untwisted line.
By the way, believe it or not I was able to find all the pieces for the intake (4" 60deg bend, 45deg bend, and 90deg coupling) at Pep Boys.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #2 of 14 (permalink) Old 08-11-2009, 01:35 PM
Snake Oil Salesman
mattr66's Avatar
Re: New Intake Set-Up
very nice! where was your mass air meter before?
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #3 of 14 (permalink) Old 08-11-2009, 01:39 PM
Don't EFN worry about it
Aljay's Avatar
Damn nice set up Danny .
Tuned by T Wildman
Aljay is offline
post #4 of 14 (permalink) Old 08-11-2009, 01:54 PM
Banning Smut
PTSUPERD's Avatar
Nice improvement Danny....although I'm still pissed at you. lol
PTSUPERD is offline
post #5 of 14 (permalink) Old 08-11-2009, 01:58 PM
Sponsor
CLIFORD3's Avatar
Nice
Jason Murff
832-73-MURFF
Murffracing.com
Proud Sponsor of Race For The Warriors
CLIFORD3 is offline
post #6 of 14 (permalink) Old 08-11-2009, 02:00 PM
Aljay's Avatar
He said it was not hooked up in the first post .
Tuned by T Wildman
Aljay is offline
post #7 of 14 (permalink) Old 08-11-2009, 02:03 PM
Aljay's Avatar
So after talking to MY Dad an law at Diesel Innovations, we decided to cut out a section of the radiator support and route the intake thru it and get the filter just behind the grill. I just used a grinder to cut out the section that needed to be removed and used some vinyl clip on trim on the edges (that we use on the lifeboats). To do it I also had to drop the a/c core down. I just made some brackets and attached the stock core supports to them, then dropped the power steering cooler down a little. While doing this I also noticed one of the trans cooler lines had a nice twist in it and was almost completely kinked. I don't really know how my trans never got hot. After that, I soldered some extensions onto the mass air meter and ran it along the piece behind the grill to the filter. I just cut out the mass air meter mount from the stock piece. I took a quick test drive last night but didn't get on it or anything. Cruising at 80mph I saw a 50-70deg drop in egt's, lol. So I'd say it's working. I'll have some better numbers today. Also, my trans was running about 15-20deg cooler with the untwisted line.
Fixed !
Tuned by T Wildman
Aljay is offline
post #8 of 14 (permalink) Old 08-11-2009, 02:07 PM
Snake Oil Salesman
mattr66's Avatar
I was looking at the pictures.........WORDS BAD (in my best caveman voice)
Hmmm it might run a little different with the meter hooked up Danny
Matt Robinson
mattr66 is offline
post #9 of 14 (permalink) Old 08-11-2009, 02:07 PM Thread Starter
imelmo's Avatar
Just zip-tied out of the way, not hooked up.
Fixed !
You're wrong too. It's dad-in-law.
imelmo is offline
post #10 of 14 (permalink) Old 08-11-2009, 02:09 PM
Aljay's Avatar
Sorry man I had to do it you been a DI person forever !!! OK I reworked it again
Tuned by T Wildman
Aljay is offline
