FASS pump help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 08-10-2009, 01:49 AM Thread Starter
SamW's Avatar
FASS pump help
Ive been running a FASS pump 150/180 for the last 6 months or so, just installed my spare which I got after the third failure. This is the 4th time ive had to change the pump in 6 months that is now on my truck but this time I was up in new jersey and made sure to bring all my tools and had to change it in a rest stop as the fuel pressure gauge dropped off. Is there a way to modify these pumps to make them more reliable. Had I not had one, that could have been a mess especially since I was about 1000 miles from my house. Anyone had any luck with airdog 2? ive heard some good, some bad on those.
2006 F250 CCSB
6.
SamW is offline
post #2 of 23 (permalink) Old 08-10-2009, 02:09 AM
Proud Sponsor
Abrannan19's Avatar
Re: FASS pump help
jeez Sam, that fricken blows man...I just don't understand these things. I have heard good things about the AirDogII but I don't have any personal experience with them. I do know that they reuse factory fuel lines, or at least they did and they retained the HFCM, or they did. But if you combine the AirDogII with the fass components, that may work..
Adam Brannan
Email
Phone (904)-813-5067
2011 F350 KR SWB CC 4x4 tuned by Ford
Abrannan19 is offline
post #3 of 23 (permalink) Old 08-10-2009, 02:57 AM Thread Starter
SamW's Avatar
Re: FASS pump help
luck of the draw i guess. once i get back in town ill have to look into it a little more. just got to make it back to florida but towing on the return trip so really hoping luck dont run out on the way back. do these pumps not like to be run for an extended period like on long trips or overheat easily?
2006 F250 CCSB
6.
SamW is offline
post #4 of 23 (permalink) Old 08-10-2009, 03:23 AM
motoxracer42's Avatar
Re: FASS pump help
i have the same pump and mine has been out 3 times now too. one time is sucked up the check ball and shorted the motor out. the other times it just shorted out.
06 crew cab
06 reg cab
motoxracer42 is offline
post #5 of 23 (permalink) Old 08-10-2009, 03:24 AM
Re: FASS pump help
there are ways of modifying them to work better ive talked to a couple guys on here that have done it.
06 crew cab
06 reg cab
post #6 of 23 (permalink) Old 08-10-2009, 02:20 PM Thread Starter
SamW's Avatar
Re: FASS pump help
I think it was an internal short again. im thinking my mod to it will be to go with the airdog 2
2006 F250 CCSB
6.
SamW is offline
post #7 of 23 (permalink) Old 08-10-2009, 03:40 PM
GunterSXR's Avatar
Re: FASS pump help
thats next on my to do list and im looking at my options as well. but isnt the airdog just an air/fuel sepperator, not a pump? im going to be runnig 225 casserlys, what would be the best option?
2005 F-350 SRW Lariat
555HP/996TQ
GunterSXR is offline
post #8 of 23 (permalink) Old 08-10-2009, 03:47 PM Thread Starter
SamW's Avatar
Re: FASS pump help
actually airdog 1 is a pusher pump to the factory hfcm, airdog 2 is new to the market and is a stand alone similarto the fass. youshould be able to fuel 225s with any of them as long as it will maintain 50-55 psi fuel pressure. also youll want upgraded fuel lines and crossover line to help maintain those injectors. should have another fass shortly to keep as a spare for the return trip. they do stand behind their product every time it fails...
2006 F250 CCSB
6.
SamW is offline
post #9 of 23 (permalink) Old 08-10-2009, 05:27 PM
Re: FASS pump help
I am having the FASS installed now, what do i need to do to get the warranty started? sounds like i may need it..........
03 F-250 207000 miles, Mad Turbo Werks Stage 1 Turbo, RCD155 injectors 100% Nozzles, 150/180 FASS, FCDP EGR delete, ARP Headstuds, OEM head gaskets, Diesel Site coolant filter kit, SCT Tunes, Hellmans Sump, 4inch Magnaflow Exhaust, 6.4 banjo bolts, AR-9100 Oil Treatment, 58v FICM
F-250-Owner is offline
post #10 of 23 (permalink) Old 08-10-2009, 05:51 PM
Proud Sponsor
Abrannan19's Avatar
Re: FASS pump help
just fill out the paper work that was in the box with the FASS and include a copy of the sales receipt I sent you.
Not all of these pumps are bad, some have no problems, mine has been installed for nearly 4 years now and never had any issues with it (knock on wood)
Adam Brannan
Email
