Dually wheel upgrade question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-18-2014, 03:18 PM Thread Starter
Mike
mrgeno's Avatar
I'm looking to upgrade my wheels/tires on my dually. What i want to do is go a little taller than stock but alot wider. I've heard tell of people pulling the bolt on spacers on front and running srw rims, any thoughts on this? I would kinda like to stick to dually fronts with maybe a 9" or 10" width with a different backspacing but i cant seem to find anything online anywhere like this. I tow a 12,000 lb excavator aroung on a regular basis so i also have to keep towability in mind. Thanks for any help y'all!
2006 F-350 CC DRW 6.0 115k miles. FICM, RevX, T-6 synthetic, Blue spring upgrade, SCT tuner, Edge CTS, egr delete, 4" straight pipe from turbo ( no cat, no muffler, BIG sound...lol ) 295/75/17 Toyo M/Ts , 2" rear spacers
I still love my truck every day....
mrgeno is offline
post #2 of 11 (permalink) Old 10-18-2014, 04:36 PM
Powerstroke n00b
Justincredible's Avatar
Re: Dually wheel upgrade question
if you want anything that wide you'll probably have to go with 22.5 or 24" wheels unless you get something custom made. I've never seen anything that wide a a dually rim..I've only seen them 6" wide.
1997 F-250 zf6, t-500 Hpop, Baby swamps, Beans D66 w/ 1.0, hydra, 6637 CAI, 6" exhaust. Kingpin D60
Boost, Oil pressure, HPOP Pressure, Water temp, Oil temp, Trans temp and EGT, fuel pressure
soon efuel and 3" plenums and intercooler.
Justincredible is offline
post #3 of 11 (permalink) Old 10-18-2014, 09:31 PM
Guilty on all counts
Picanins's Avatar
I took my dually adapters/spacer off the front and put on my old 7" wide Excursion wheels on. Looks and works fine. To run something wider in the back you will probably need to use spacers between them to keep them from touching. They are pricey, but get good steel ones, like from Fred Goeske (sp?).
2000 Excursion 4x4 7.3
2000 F350 4x4 CC SWB
1988 Suzuki Samurai 4x4 (can I squeeze a 7.3 under the hood?)
Picanins is offline
post #4 of 11 (permalink) Old 10-18-2014, 10:27 PM
Powerstroke n00b
I currently run 315s on my stock 6" wide wheels. And i have a dually. I have 3" spacers for the rear from Fred and they work fine. Ive hauled probably 14k or better with no issues this far.
post #5 of 11 (permalink) Old 10-19-2014, 02:31 AM
06.0dually's Avatar
American force 22.5 dually wheels. You gotta buy the 10 lug conversion. Those are a lot wider wheels. They look great with 315s. My dad has some on classic american force rims.
I have the 19.5 classic american force. But those are bolt on. You don't need a 10 lug adapter. But the rims are only 7" wide.
The 22.5s are a good 2"s wider
Alcoa might even make sum rims that are deeper. You gotta search a lot.
And my dad's truck with the 22.5s doesn't even need a spacer in the rear. And he tows bobcats, and excavater buckets all the time . On my truck I could use a spacer if I towed heavier like him.
06 f350 white crew cab dually, 225/100 warrens, barder 68, BTS, Fuel lab setup built by tsd, sct tuned by tsd, ppe up pipes,bd exhaust manifolds, secret dual oil kit ,CTS monitor, a lot more extras
01 f350 red extended cab dually, powermax 38r, BTS, cfm, Afe, 6 inch danahoe, tsd 6 pos, a lot more extras.
06.0dually is offline
post #6 of 11 (permalink) Old 10-20-2014, 11:20 PM
PursuitInterceptor
HeavyAssault's Avatar
The options are quite limited on wide wheels for DRW trucks. I think it's Fuel that has some at 8" wide. Most will cover the weight range needed to stay within the tow ratings.
Now Rickson Wheels will make some DRW to SRW conversion wheels that will run with the DRW bed.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #7 of 11 (permalink) Old 11-14-2014, 02:29 AM
Look at eagle alloy wheels they make 20" dually wheels the rear's have a built in lock system that lock the 2 wheels together and makes the outer sit center.
https://www.facebook.com/EagleAlloys...type=3&theater
6.0 P/S Lariat FX4 CC/SB
37/12.50/20 nitto trail grappler 20'' black badlands
6inch lift
Mbrp Turbo Back Exhaust Cat Delete, Muffler Delete, 6Inch Tip,SCT Tuned By Eric,AFE Stage 2
Arp studs
Egr Junk deleted
Water Trans Egt Boost Fuel Phantom 2
Airdog 150, dozer diesel stage 2 RR, Fuel sump
stroker_1999 is offline
post #8 of 11 (permalink) Old 11-14-2014, 02:30 AM
https://www.facebook.com/media/set/?...9272722&type=3
6inch lift
Arp studs
Egr Junk deleted
post #9 of 11 (permalink) Old 12-11-2014, 03:00 AM
That's tough no doubt. I went with 285s with 2" spacers in the rear. Couldnt justly the cost of going with 22 or 19.5 wheels and tires.
-=StoneRhino=-
2004 F-350 CC DRW AT 4x4. Complete motor rebuild in progress.
2005 Dodge Ram 3500 SRW AT. Stage 1 ATS tranks, ii100hp injectors, head studs, 5" to 4" dual exhaust
StoneRhino is offline
post #10 of 11 (permalink) Old 12-11-2014, 03:09 AM
Here is a pic
-=StoneRhino=-
