My Transmission is sticking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-13-2014, 07:18 PM Thread Starter
Need some help. Transmission won't shift until I get her up to 2500 rpm. Cruising at 25 mph in second gear its really revving. When coasting down hill and hit the throttle, it down shifts.
Also when tow/haul button is pressed while driving it slams into low gear. Really slams.
djbinding is offline
post #2 of 6 (permalink) Old 10-13-2014, 09:05 PM
JGman141
Jgman141's Avatar
Re: My Transmission is sticking
Do you have any tuning?
Jgman141 is offline
post #3 of 6 (permalink) Old 10-13-2014, 11:01 PM
Any recent changes or work done on the truck?
Have you had the transmission codes read out? If so, what are they?
2006 F-250 6.0 Auto CC SB 4x4
charlez is offline
post #4 of 6 (permalink) Old 10-13-2014, 11:11 PM
bluesbish's Avatar
you most likely have an engine issue such as low boost that is causing a severe lack of power. this will delay your shifts in the way you are describing.
bluesbish is offline
post #5 of 6 (permalink) Old 10-13-2014, 11:44 PM Thread Starter
Had EGR delete. No tunes. Had a Transmission shop diagnose it. They said the transmission was shifting on command. Then i had the guy who did the 4 injectors and egr delete drive while hooked up to computer. All the pressures seemed normal to him.
There were tunes as part of EGR delete. But it just seems odd that this started happening after the EGR delete was done.
The most concerning thing is when the Tow/Haul slams into gear. I have to come to complete stop before I apply it.
post #6 of 6 (permalink) Old 10-13-2014, 11:46 PM Thread Starter
I don't know about the low boost issue cuz she goes like a raped ape now. No lack of power at all.
