injector rebuild - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-07-2014, 10:20 PM Thread Starter
injector rebuild
Who does good affordable injector rebuilding pretty disappointed don't even have 15,000 miles on these injectors and 3 have already #### out on me
2004 f-250 ccsb,RCD 68mm powermax, 205/100 warren injectors, airdog 2, regulated return/fuel bowl delete,egr delete, banks intercooler, banks ram air intake, banks intake manifold, 4'' exhuast,sct hand held,studded, ams oil oil bypass, coolent filter, 6 inch fabtec lift ,37x13.50x18 toyos
Speedinpolaris is offline
post #2 of 6 (permalink) Old 10-07-2014, 10:46 PM
Re: injector rebuild
Nobody really , ford is still best option unfortunately there quality is not what it was a year ago. in an effort to reduce cost ford no longer replaces the spool valve, they only replace it "if needed" they lowered the cost 20 bucks now they reuse a bunch of parts like every one else
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #3 of 6 (permalink) Old 10-07-2014, 10:54 PM Thread Starter
Well that's not good to hear after I spent almost $2,000 on these 205/100
post #4 of 6 (permalink) Old 10-07-2014, 11:22 PM
I bought close to 400 6.0 injectors last year from ford iirc had 5 failures we installed 4 sets of performance injectors 1 of them is still running without failure. 2 have had injectors exchanged by the builder 1 over fueled melted piston 155/30.
wise guy is offline
post #5 of 6 (permalink) Old 10-08-2014, 09:03 PM
fueled by Colecovision
golfer's Avatar
Garage
yeah..there is NO good rebuilt 6.0L injector..
Ford Motorcraft are the ONLY injectors to build from...even if you want a modified set.
the spool valve is a POS design...and no amount of 'rebuilding' is going to bring the spool (to bore) clearance back..
it would be like rebuilding a low compression engine and not doing .010, .020, etc oversized pistons...
So far this year we've sold over 600 Motorcraft injs (or modified injs built FROM Motorcraft)..can't remember any having to be warrantied.
golfer is offline
post #6 of 6 (permalink) Old 10-08-2014, 11:10 PM
Unfortunately as of January of this year ford is now reusing spool assemblies.
wise guy is offline
