6.0 turbo change/upgrade? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-26-2014, 02:13 AM Thread Starter
I've got a 2003 f250 6.0 all stock. It's got 187,000 miles. This past weekend I changed the ICP sensor and found some issues with the wiring. So I was like great well at least I found this before it became a major problem! Then I found the wires at the IPR harness damaged. Then I looked closer at my turbo and noticed there is a chip missing out of the compressor wheel. So now do I rebuild the turbo? Replace the turbo with an upgrade or stock turbo?? Can I upgrade the turbo with the truck being stock or is it a waist of time.whats the best turbo to replace this one with?
olgreydog is offline
post #2 of 6 (permalink) Old 09-26-2014, 02:39 AM
06.0dually's Avatar
Re: 6.0 turbo change/upgrade?
Do a powermax. Unless you want to spend more money on a custom one like barder and kc. A powermax is 1200$
Barder and kc are the best custom powermaxs out there. They cost a little more but well worth it.
06 f350 white crew cab dually, 225/100 warrens, barder 68, BTS, Fuel lab setup built by tsd, sct tuned by tsd, ppe up pipes,bd exhaust manifolds, secret dual oil kit ,CTS monitor, a lot more extras
01 f350 red extended cab dually, powermax 38r, BTS, cfm, Afe, 6 inch danahoe, tsd 6 pos, a lot more extras.
06.0dually is offline
post #3 of 6 (permalink) Old 09-26-2014, 12:56 PM
Swamp trash...
Merc82's Avatar
Up to you if you want to upgrade. Depends on how you use your truck. With that many miles on the turbo. It would be worthwhile to rebuild it.
Chris. 06 LBCC XL 44
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #4 of 6 (permalink) Old 09-26-2014, 11:54 PM Thread Starter
I'll look into kits to rebuild it once I get it out. It was running ok! But I don't really beat it up much. So I think rebuilding it would be ok if I find the rt priced kit.
post #5 of 6 (permalink) Old 09-27-2014, 01:38 AM
2Dstorm's Avatar
Ford 6.0L Turbocharger Billet Unison Rings - Turbos
Call Nate he can hooked up with a rebuild kit for a reasonable price
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Fass titanium 125 w/ sump
Volant intake
5" mrbp turbo back 6" tip
Reg. return w/6.4 banjos and oil and coolant filter
Sct itsx on iPad w/ Drew's tunes
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
post #6 of 6 (permalink) Old 09-27-2014, 01:39 AM
2Dstorm's Avatar
Looks like a full rebuild kit with a new wheel will run about 285
Pmax & batmowheel
Banks technicooler
Arp's
Warren 175/75's
Volant intake
Idp ficm tune
Snow water/meth
Empty bank account
2Dstorm is offline
