CCV reroute, Let me know what you guys think! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-25-2014, 07:17 PM Thread Starter
06regcab6.0's Avatar
So I had my pops make me a metal plug for the intake tube. then I bought 10 feet of 1in heater hose and routed it along the frame. I wasnt sure if the low point in the hose would cause a puddle of oil to form and clog it so i drilled an 1/8 hole in the bottom of the hose at the lowest point. let me know if i should make a change to it.
Thanks
2006 f350 sclb 2wd XLT, studded, deleted, Irate T4 kit, Box 366, RCD 225/100s, Gearhead tunes, Homemade 4in intake, sct 5015, single stack, lowered.
06regcab6.0 is offline
post #2 of 11 (permalink) Old 09-25-2014, 09:15 PM
JGman141
Jgman141's Avatar
Re: CCV reroute, Let me know what you guys think!
The bad thing about having the line so long is that it can crate more back pressure then it should have in the system. I use to run mine the same way but now I have it running straight down in the wheel well. Far less hose and it's only has to travel about 2 feet.
Jgman141 is offline
post #3 of 11 (permalink) Old 09-27-2014, 05:40 AM
MT KingRanch's Avatar
Just did mine today, stuck a pvc plug in the inlet duct and clamped it, clamped 6' of 1" heater hose to the OEM elbow on the valve cover, zip-tied it to the frame, stuck the 90 degree elbow in that to direct it down an Let 'Er Buck!!
Was surprised as how much vapor was coming through, NOT back into my turbo and Intercooler lines.
04.5 F-350 KR. ARP studs, Sinister Wrapped Y-Pipes and R.R. Fuel System,Atlas40 FICM, DC Power 190Alternator,BPD remote oil cooler&updates,BPD Water Pump/7.3 Fan Clutch, EGR Cooler delete,DieselSite Coolant Filter, AEM Brute Force HD intake, 4" Flow-Master,2.5" Level Kit/33" Toyo AT II's, D.D. Solenoid Mod, CCV Delete. SCT X4. KC Stage 1.5 Turbo.
MT KingRanch is offline
post #4 of 11 (permalink) Old 09-28-2014, 07:45 PM Thread Starter
Thanks for the replys, sounds like I should shorten up mine a bit!
post #5 of 11 (permalink) Old 09-29-2014, 04:36 AM
Yeah, no sense in giving that sticky crap any chance to pool and build up in a long run of hose.
Mine ends right before the tranny crossmember, if it gets a little greasy underneath, will head it off at the carwash.
post #6 of 11 (permalink) Old 10-01-2014, 12:29 PM
I have mine just dumping in the fender well too. Gets some looks at red lights when its cold out. Have thought about running it into the exhaust at a angle to create a vacuum to suck it out. Summit and jegs sells a header kit for racing.
mossyoak is offline
post #7 of 11 (permalink) Old 10-02-2014, 12:14 AM
superbad's Avatar
I have mine run down my frame about 8' like others have. I did consider running it shorter down the fender well, my old 12v and 24v dodges ran it short down.
I'd be interested in running it to the exhaust, can you give more info on the Summit/Jegs header kit?
2008 F250 KR CCSB AT MINIMAXX AFe PG7 5" straightpipe. SOLD!
2007 F250 KR 4x4 CCSB Scan Gauge II, SCT SF3, Gearhead's SRLXX, ARP's, PMM's EGR delete, PMM's coolant filter, Rancho 7000's, IDP FICM tuning, blue spring, Wicked Wheel, No Limit Fab CAI.
2006 GMC Savanna 3500 6.6 LBZ Duramax work van
superbad is offline
post #8 of 11 (permalink) Old 10-02-2014, 02:03 PM
'05 Excursion
Term3's Avatar
Like this.....
Term3 is offline
post #9 of 11 (permalink) Old 10-02-2014, 08:07 PM
superbad's Avatar
I like it. Is this available for purchase?
superbad is offline
post #10 of 11 (permalink) Old 10-03-2014, 02:23 PM
'05 Excursion
Term3's Avatar
Not that I know of as it was just a picture a buddy used to do his SD except he just did one tube.
Term3 is offline
