Running dual hpops - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 09-09-2014, 08:51 PM Thread Starter
06.0dually's Avatar
Running dual hpops
Whose running successful dual hpops? And how much of a difference did they make when added? How is your setup hooked up?
06 f350 white crew cab dually, 225/100 warrens, barder 68, BTS, Fuel lab setup built by tsd, sct tuned by tsd, ppe up pipes,bd exhaust manifolds, secret dual oil kit ,CTS monitor, a lot more extras
01 f350 red extended cab dually, powermax 38r, BTS, cfm, Afe, 6 inch danahoe, tsd 6 pos, a lot more extras.
06.0dually is offline
post #2 of 18 (permalink) Old 09-10-2014, 02:05 AM
JGman141
Jgman141's Avatar
Re: Running dual hpops
I've been running mine for awhile and it makes a big difference in power. I don't know how much of an increase you'll see with 225 bit you should feel some.
Jgman141 is offline
post #3 of 18 (permalink) Old 09-10-2014, 10:16 PM Thread Starter
06.0dually's Avatar
How much horse power did you gain?
post #4 of 18 (permalink) Old 09-10-2014, 10:53 PM
Stroke it B!tch
fordboy11's Avatar
Well I was running 190/75 then jumped up to 225/100 with dual pumps and wow there was a huge noticeable gain. She's never been on the dyno though.
78 F-150 300 straight 6, 3 on the tree
03 F-250 6.0 Play toy
06 F-250 6.0 (general nightmare) 2.5 pulling truck
12 F-350 6.7 Tow rig
Gotta pay to play son!
Originally Posted by F-250-Owner View Post
I know you said you wouldnt turn it up..... but come on.... its like saying "I promise I will only stick the tip in" never happens like that
fordboy11 is offline
post #5 of 18 (permalink) Old 09-11-2014, 12:14 AM Thread Starter
06.0dually's Avatar
Who makes them? Is it a reliable setup?
post #6 of 18 (permalink) Old 09-11-2014, 12:31 AM
JGman141
Jgman141's Avatar
Not sure how much was gained but my butt dyno felt the increase. Mine has been reliable so far.
Jgman141 is offline
post #7 of 18 (permalink) Old 09-11-2014, 12:52 AM
Warren diesel makes them and he has had success with his set up.
seeemmiss is offline
post #8 of 18 (permalink) Old 09-11-2014, 06:57 PM Thread Starter
06.0dually's Avatar
Do you have any problems with it pulling from the oil pan? As in suction?
Isn't the warren pump a skidsteer pump?
How many miles have you had on those setups? I've heard some of those pumps aren't made to be belt driven
post #9 of 18 (permalink) Old 09-11-2014, 07:00 PM
JGman141
Jgman141's Avatar
You just have to make sure that you prime the pump correctly. I'm working on a low pressure oil pump to feed mine because then I know it always has oil to push.
Jgman141 is offline
post #10 of 18 (permalink) Old 09-12-2014, 02:59 AM Thread Starter
06.0dually's Avatar
I won't be using warrens pump/setup so I won't have to worry about that design.
That's my main concern is the lpop. But I've heard problems start happening when you go above 4000 rpms. Like 5500 Rpms.
Did yours come with a intercooler pipe? What hp are you sitting at ?
