ww2 or powermax - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 09-06-2014, 06:08 PM Thread Starter
ww2 or powermax
Any help deciding between the 2 would be apreciated greatly! Have the wheel already but I'm looking for lower egts when towing 15k. Is there a big enough difference between the 2 to merit spend 1000 more? Have banks intercooler already.
tazz is offline
post #2 of 14 (permalink) Old 09-06-2014, 09:45 PM
Swamp trash...
Merc82's Avatar
Re: ww2 or powermax
A larger turbo isn't going to net you lower EGTs.
Chris. 06 LBCC XL 44
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #3 of 14 (permalink) Old 09-06-2014, 11:01 PM
Re: ww2 or powermax
How high are your egts?
Where are you having problems with egts? Cruising at 65mph or going up big hills?
What size tires?
What year truck?
peixinho is offline
post #4 of 14 (permalink) Old 09-06-2014, 11:05 PM
PursuitInterceptor
HeavyAssault's Avatar
Re: ww2 or powermax
Drop that WW2 for a single plane compressor wheel. See what happens to the EGTs after the install. IF you need something more jump to a Pmax with a single plane compressor wheel.
The Pmax will tend to be a bugger on the low end but the top end shines. The single plane compressor wheel helps out both the stock turbo and Pmax.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #5 of 14 (permalink) Old 09-07-2014, 01:03 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: ww2 or powermax
Single plane compressor wheels FTMFW.....
In all seriousness, I've had better luck with single plane wheels than dual plane wheels in the stock to stage 1/pmax size turbos. It really comes down to wheel design and the wheel options that are available out there do a really good job at out-performing the stock cast wheels.
Nate
windrunner408 is offline
post #6 of 14 (permalink) Old 09-07-2014, 02:36 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: ww2 or powermax
I have a WW in my stock 05 turbo. Only difference I notice is the sound.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #7 of 14 (permalink) Old 09-22-2014, 02:15 AM Thread Starter
Re: ww2 or powermax
Ok got the ww2 in for a week now and to be honest very little difference in egts. It does sounds a bit nicer though!!
tazz is offline
post #8 of 14 (permalink) Old 09-27-2014, 05:45 AM
MT KingRanch's Avatar
Re: ww2 or powermax
Sounding nicer taint work the hassle or the cost!!
04.5 F-350 KR. ARP studs, Sinister Wrapped Y-Pipes and R.R. Fuel System,Atlas40 FICM, DC Power 190Alternator,BPD remote oil cooler&updates,BPD Water Pump/7.3 Fan Clutch, EGR Cooler delete,DieselSite Coolant Filter, AEM Brute Force HD intake, 4" Flow-Master,2.5" Level Kit/33" Toyo AT II's, D.D. Solenoid Mod, CCV Delete. SCT X4. KC Stage 1.5 Turbo.
MT KingRanch is offline
post #9 of 14 (permalink) Old 09-27-2014, 04:44 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: ww2 or powermax
Only reason mine is still installed is because I don't feel like pulling the turbo to remove it.
But, if anyone wants to try the WW, I'll have one for sale here within a mth or so. If I ever make time to tear the truck down.
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #10 of 14 (permalink) Old 09-30-2014, 09:32 PM Thread Starter
Re: ww2 or powermax
I went and picked up a powermax! Anyone wanna buy a 06 turbo w ww2 installed?
tazz is offline
