sct livewire questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 09-05-2014, 03:46 PM Thread Starter
I purchased a new sct livewire a few days ago and when I am at an idle it is showing my turbo boost at -2 psi... also my battery voltage drops to 10.5 volts when I am cranking to start but goes up to 13.75 or so once its running... the turbo psi is my main concern bc I plan on purchasing 2 new batteries on pay day. Does anyone else have this psi reading or do I have a problem or could it be because my current elevation is 5500 ft? Any answers from the powerstroke gods would be great lol
fluegy is offline
post #2 of 5 (permalink) Old 09-05-2014, 05:11 PM
JGman141
Jgman141's Avatar
Re: sct livewire questions
It's the elevation, I drove through Colorado once and at one point I had -5 lbs.
Jgman141 is offline
post #3 of 5 (permalink) Old 09-05-2014, 05:17 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
other vehicles i have show around 10 volts when cranking. i think that's normal when a high current is being drawn. kinda like to hear more though
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #4 of 5 (permalink) Old 09-05-2014, 10:19 PM
jtgf250's Avatar
Don't waste the money on batteries. Its normal to drop down like that while cranking til the glow plugs go off and the alternator kicks in. If your that concerned about them then pull the batteries and get them load tested. If they are coming up the 13.5 though you have no issue.
I would guess the elevation is your boost issue. I can say that I am running the Livewire in my 6.0 for gauges right now but will adding a pillar as soon as funds allow. Not a big fan of the digital ones.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #5 of 5 (permalink) Old 09-06-2014, 12:30 AM Thread Starter
thank you for the info guys I really appreciate it.
fluegy is offline
