Suggested upgrades for towing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-04-2014, 12:25 AM Thread Starter
What would you suggest be upgraded for towing 8k+ trailer.
Truck has juice programmer from 05' otherwise it's a stock truck.
I'm going to be installing firestone air bags but don't know if I need the compressor or not. If possible add at a later time?
Love to hear your thoughts!
sdp0024 is offline
post #2 of 10 (permalink) Old 09-04-2014, 12:47 AM
Work&Play's Avatar
Re: Suggested upgrades for towing
First get rid of the juice and get an SCT programer. Your tranny will thank you.
Next get some gauges to keep an eye on things.
Your truck will not even know you have 8k behind you.
Andy 2007 4X4 F350,6.0 PSD, Lariat, CC, DRW, 9' Knapheide body, stainless steel ladder rack, SCT with custom tunes, Banks turbo back, ARP's, ITP RR, Airdog II, Powermax with Billet Wheel, Firestone air bags, Autometer gauges( pyro,fuel pres,water temp,boost,trans temp), CCV mod.
Work&Play is offline
post #3 of 10 (permalink) Old 09-04-2014, 02:45 AM
JGman141
Jgman141's Avatar
also look into a ported intake manifold to help with egts.
Jgman141 is offline
post #4 of 10 (permalink) Old 09-04-2014, 06:28 AM
Administrator
Zmann's Avatar
does anyone have real world info on the ported EGT's ??
you can ad the compressor whenever
sway bars can be nice and good shocks
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 10 (permalink) Old 09-04-2014, 09:13 PM
Depending on trailer tongue weight I think the truck will handle it fine. I have towed 8K-10K with both of mines no issues. I don't think you will need airbags unless the tongue weight if really high but that also depends on your suspension is it a F250 or 350?
Like one said earlier your tune might be something you want to check. I have heard that canned tunes can burn out trans. I would use only stock or custom tune.
03 Excursion Ltd 4x4, ARP studs/HG, EGR deleted, K&N CAI, turbo back exhaust, 6.4L banjo bolts, blue spring, coolant filter, IDP tunes, SCT Livewire
07 F250 King Ranch 6.0L SB (for sale)
96 Regal 258 Commodore
08 Jayco 31 BHDS G2
rowekmr is offline
post #6 of 10 (permalink) Old 09-05-2014, 12:53 AM Thread Starter
It's a 250 and sags more than I like. Have Bilstein shocks and stabilizers as well.
sdp0024 is offline
post #7 of 10 (permalink) Old 09-05-2014, 12:55 AM Thread Starter
I forgot to mentioned that I have Magniflow exhaust, S&B intake, BPD oil cooler and BPD EGR cooler.
What other guages should I get and monitor?
sdp0024 is offline
post #8 of 10 (permalink) Old 09-05-2014, 09:42 AM
Work&Play's Avatar
EGT's, fuel psi, water temp.
I also have turbo psi, volts, tranny temp, oil temp, FICM volts.
A Edge CS or CTS is a good option.
I just like the old school gauges.
post #9 of 10 (permalink) Old 09-07-2014, 11:16 PM
Swamp trash...
Merc82's Avatar
I dropped 100-150į with mine. Everybodies setup is a little different though.
Chris. 06 LBCC XL 4◊4
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #10 of 10 (permalink) Old 09-08-2014, 11:47 PM
SledDogg's Avatar
I tow new RV trailers for a living with my 06' F250 that is stock other than studs, Driven Diesel Coolant return kit, and SCT X4. I tow in Tow 65......no gauges, no bags, just a truck lol. 59,000 miles in less 90 days.
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
