Horn messed up?! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 08-16-2014, 06:12 PM Thread Starter
MattFoster55's Avatar
Horn messed up?!
So before I went out to sea the morning I was leaving I got to my truck an put my key in an the horn went off I took the key out an it was still going off so I had to leave it going an ride with someone else cause I didn't have time to fix it an wanted to know if anyone's had this problem an had to fix it? Any help would much greatly been appreciated
2006 F350 ext cab long bed 6 spd.starting all over on her.general grabber A/T 2 powermax,egr delete,gaskets,sct,mbrp 4" straight pipe exhaust,blue spring kit,glow shift gauges,sinister coolant filtration kit.
MattFoster55 is offline
post #2 of 12 (permalink) Old 08-16-2014, 06:19 PM
Administrator
Zmann's Avatar
Re: Horn messed up?!
not unheard of
I would check the horn button it may be a clockspring issue and i would also check the horn relay probably start at the relay and save the wheel for last
the horns themselves are buried but you can get to the wires to disconnect near the pass battery IIRC
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 12 (permalink) Old 08-16-2014, 06:20 PM
Administrator
Zmann's Avatar
you have a manual with fuse relay locations ?
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 12 (permalink) Old 08-16-2014, 06:39 PM Thread Starter
Yep I'm gonna check the fuses
post #5 of 12 (permalink) Old 08-16-2014, 07:18 PM Thread Starter
We'll fuse was bad so got a new one an put it in an horn still Goin off
post #6 of 12 (permalink) Old 08-16-2014, 09:34 PM
Administrator
Zmann's Avatar
interesting
i would check for a hung relay
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 12 (permalink) Old 08-16-2014, 10:01 PM
Luddite in Charge
Mr_Andy's Avatar
From jabbing the horn/steering wheel cushion with a clenched fist just to give a 'toot' for whatever reasons enough times, I had a similar thing happen.. But it was as I was going into a turn and spinning the wheel, not just inserting the key. I took it apart and a sliver of plastic wedged behind the contact disc or whatever it's called pushing it out and in touch with the other contact. I was pulling into a parking lot anyway and just quick popped the hood and ripped the wires behind the driver side headlight that feed the horn.
Mr_Andy is offline
post #8 of 12 (permalink) Old 08-16-2014, 10:36 PM
Administrator
Zmann's Avatar
08 horns on the driver side ?
06 is pass side
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #9 of 12 (permalink) Old 08-17-2014, 04:29 PM
Luddite in Charge
Mr_Andy's Avatar
06 is pass side
No, this was on my last Chevy, a '98.. They're on each side of the radiator on those buut the power comes from the drivers side then over to the second horn so kill driver side and pass side goes too
Mr_Andy is offline
post #10 of 12 (permalink) Old 08-17-2014, 06:18 PM
Luddite in Charge
Mr_Andy's Avatar
I mentioned that more as an example to suggest looking towards the clockspring / steering wheel for his culprit
Mr_Andy is offline
