03 6.0 fuel upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-13-2014, 10:14 AM Thread Starter
03 6.0 fuel upgrade
I currently bought a 03 f350 with 6.0 and the guy before me did the deletes and head studs . He also replaced the injectors with 170 cc injectors. Now I'm faced with upgrading my fuel system . I'm looking for so info and the best route I can go to upgrade this .my man factor is doing it right so I don't burn these injectors up
Smokey 03 is offline
post #2 of 5 (permalink) Old 08-13-2014, 10:35 AM
JGman141
Jgman141's Avatar
Re: 03 6.0 fuel upgrade
A regulated return will help a lot with the ability to maintain fuel pressure. Also being able to monitor the fuel pressure crucial with a 6.0, I'd be looking at gauges or a monitor that can read the fuel pressure.
Jgman141 is offline
post #3 of 5 (permalink) Old 08-13-2014, 10:48 AM Thread Starter
I have a fuel pressure gauge and it drops a lot at wot depending on temp outside .it drops from 60 psi to as low as 30 psi
post #4 of 5 (permalink) Old 08-13-2014, 10:48 AM
Swamp trash...
Merc82's Avatar
I agree with JGman. I would so some sort of sump and maybe some sort of lift pump setup as well.
Chris. 06 LBCC XL 4◊4
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #5 of 5 (permalink) Old 02-09-2015, 01:11 AM
Banned
If you are dropping to 30 psi under a load you will have injector problems very soon.You should never dry pop a 6.0 injector and at that pressure you
are extremely close.
equalizer is offline
