blew the top off the rad - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 08-11-2014, 01:06 AM Thread Starter
Blew the top right off my radiator so I ordered a new Mishimoto rad and hoses...thinking about removing the clutch fan and going with an electric one...highest cfm I've found is 5500...any by one ever do this?
swizzles6.0 is offline
post #2 of 16 (permalink) Old 08-11-2014, 01:59 AM
cpdad93's Avatar
Re: blew the top off the rad
how did it build enough pressure to blow the top off the radiator
cpdad93 is offline
post #3 of 16 (permalink) Old 08-11-2014, 01:59 AM
Administrator
Zmann's Avatar
scary
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 16 (permalink) Old 08-11-2014, 03:12 AM Thread Starter
The stock rads are only held together up top with those ring clamps...I would imagine with more hp more pressure is being built up in the motor
post #5 of 16 (permalink) Old 08-11-2014, 03:15 AM
Administrator
Zmann's Avatar
we know they are crimped ABS caps on aluminum radiators
but no one blows the tops off ( or it's not a known of issue)
so we are worried you have a bad head gasket to build that much psi and normally the Degas cap can keep up with a HG issue so I would make sure you don't have an issue before you throw a lot of money at a radiator
or do the mishi since you really need a good radiator to test
but put a psi guage on the cooling system so you can test for a bad HG right away
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 16 (permalink) Old 08-11-2014, 03:26 AM
I agree find the problem don't just fix the symptom.
lenzhotrod is offline
post #7 of 16 (permalink) Old 08-11-2014, 03:33 AM
cpdad93's Avatar
The spring in the cap should have relieved pressure long before a radiator came apart.
cpdad93 is offline
post #8 of 16 (permalink) Old 08-11-2014, 03:39 AM
Not always! Depends on how big of a head gasket problem.
post #9 of 16 (permalink) Old 08-11-2014, 03:42 AM Thread Starter
I'll throw a gauge on it...I had head studs done about a year ago with stock gaskets put on...only ones my mechanic trust...I would hate to have to redo it again but unfortunately if that's the problem then I'll address it accordingly
post #10 of 16 (permalink) Old 08-11-2014, 03:43 AM
Administrator
Zmann's Avatar
good call
and no one knows if the cap was bad
all things to check may just be an anomaly
but worth looking at
DTR's Donation page
RIP DTR Ron
Zmann is offline
