Still puking with studs?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 38 (permalink) Old 11-29-2007, 02:58 AM Thread Starter
Diesel Junkie
Sean's Avatar
Send a message via AIM to Sean Send a message via Yahoo to Sean
I've had my head studs in for a touch over 20k now and have noticed that either while pulling or running a higher setting that I'll get some puking out of the degas bottle. If I'm driving sane, I don't see any coolant loss, just under 'extreme conditions'
Is this common?
2006 F-350 4x4 King Ranch
Sean is offline
post #2 of 38 (permalink) Old 11-29-2007, 03:01 AM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: Still puking with studs??
Is this common?
EGR cooler is leaking.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #3 of 38 (permalink) Old 11-29-2007, 03:06 AM Thread Starter
Diesel Junkie
Sean's Avatar
Does it harm anything or just create an annoyance?
Sean is offline
post #4 of 38 (permalink) Old 11-29-2007, 03:10 AM
It will not hurt anything, but it will eventually get worse and replacing or welding up the EGR will be the only fix.
David Lott
post #5 of 38 (permalink) Old 11-29-2007, 02:13 PM
ROCKSTAR
OneTonHillBilly's Avatar
Mine did it the next day but it was my Degas bottle. They replaced the bottle and cap after cooler and HG's and ARP's. It's fine now on high tune and driving it hard.
2007 F-350 SRW LARIAT OUTLAW
You must be fast 'cause you were hauling ass when I passed you!!
OneTonHillBilly is offline
post #6 of 38 (permalink) Old 11-30-2007, 08:00 PM Thread Starter
Diesel Junkie
Sean's Avatar
I've had everything replaced (heads, gaskets, egr cooler, egr, oil cooler, degas bottle and cap) initially. Then ~7k later the egr was replaced again.
I'm at the point where I'd like to bypass everything.
I pulled the tune off and have been running stock the past few days (I've resorted to huffing while driving to make it more exciting) If the egr cooler is leaking does it throw any DTC's? Not losing any coolant right now.
Do the studs need to be retorqued?
Sean is offline
post #7 of 38 (permalink) Old 11-30-2007, 08:59 PM
Sponsor
Logan21SV's Avatar
Who did your studs? They make an egr delete up-pipe. What Tuner are u running? You can get the up-pipe in 2 styles one that looks as if everything was still hooked up like factory and another that is smooth (no connection to the Cooler). With either of these you have to have a custom tune to turn off the EGR valve. EliteDieselEng.com has both. This will take care of your puking problem if the head studs were done correctly.
CenTexDiesel.com
Logan Schneider
830-885-6500
Logan21SV is offline
post #8 of 38 (permalink) Old 12-01-2007, 03:13 AM
Diesel Addict
BilletGarage's Avatar
My truck is at the dealer right now for gaskets/studs. They have done quite a few ARP stud installs but is there anything I should ask or "remind" them to do during the install?
BilletGarage is offline
post #9 of 38 (permalink) Old 12-01-2007, 11:22 AM
ROCKSTAR
Ask them to make sure they hook the flux capacitor back up! Be patient with them and let them do it right. Drop a 12 pack off to the tech!
post #10 of 38 (permalink) Old 12-01-2007, 11:53 PM
Diesel Addict
The flux capacitor . . . The reason I was asking was Logan mentioned in his last post.
Just wondering if there were known problems with installation, torque sequence, etc.
