6.0 turbo upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 52 (permalink) Old 07-15-2014, 02:18 AM Thread Starter
jdrescher's Avatar
6.0 turbo upgrade
What's everyone's opinion on the best turbo upgrade to run with stock injectors probably won't go much bigger than 155s down the road. Will be studding it soon. I'm trying to decide between a powermax, barder turbo stage 1, mtw stage 1 thanks
1996 F-350 4x4 Reg Cab SRW,255,000 ~3.55~BTS E4OD~D66 turbo~SD intercooler~RDS stage 1's~Adrenaline HPOP~DP tuner~Labonte Water-Meth kit~3in DP to 5in exhaust~Tymar intake~Boost,Pyro,Trans temp gauges~Gutted EBPV
~1997 F-250 4x4 CCSB 12 valve Cummins,zf 5, D 60 front, 4in bds lift, 315/70-17 nitto trail grappler mt on eagle 186s
jdrescher is offline
post #2 of 52 (permalink) Old 07-15-2014, 08:49 AM
Good ol boy
04 f350's Avatar
Re: 6.0 turbo upgrade
I'm partial to the barder myself, I have the stage 2 and LOVE it. And not to mention James is one of the most helpful people you will ever meet, his customer service alone is what sold me.
Studded and Deleted
5 inch axle dump
Back Road Performance Tuned
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #3 of 52 (permalink) Old 07-15-2014, 11:01 AM
Swamp trash...
Merc82's Avatar
Any of those should work fine with those injectors. However I would suggest one of the stage 1s. Both of those are similar, however the powermax is different. Those "stage 1" turbos utilize the 13 bladed turbine with the smaller A/R that the newer trucks use, this means quicker spooling and a great street truck. The powermax uses the larger 10 bladed turbine, it doesn't spool as quick but flows a little more air and creates that whistle that the 03 turbo is famous for, I would recommend it if you plan on going bigger in the future. Also, the only way to run a powermax is to put a billet wheel on it, but you can buy them new. I would go stage 1 with the gains you are looking for.
Chris. 06 LBCC XL 44
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #4 of 52 (permalink) Old 07-15-2014, 11:14 AM
Good ol boy
04 f350's Avatar
Agreed...either stage 1 with 155s is going to be a nice gain.
Studded and Deleted
5 inch axle dump
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #5 of 52 (permalink) Old 07-15-2014, 02:54 PM
Stage 1.5
Spool up faster
Quieter Operation
Recommended for those who tow heavy or have really big tires
Stage 2
More Top end HP
Really loud whistle
Recommend for those looking to get the most hp possible without stepping up to a stage 3 turbo
peixinho is offline
post #6 of 52 (permalink) Old 07-15-2014, 03:54 PM
Good ol boy
04 f350's Avatar
Originally Posted by peixinho View Post
Stage 1.5
Spool up faster
Quieter Operation
Stage 2
More Top end HP
Really loud whistle
I was going to suggest the 1.5 or even the one I have simply because the powermax is goin to run you between 1100 to 1300 depending on where you order it from and then your lookin at another 3-400 bucks for the billet wheel, I paid 1600 for my stage 2 and it was well worth it. And yea it whistles really loud lol
Studded and Deleted
5 inch axle dump
Barder Stage 2
58v IDP Ficm tune
04 f350 is offline
post #7 of 52 (permalink) Old 07-15-2014, 04:29 PM
06-6.0 stoker's Avatar
I would step away from the powermax. Not worth it IMO. A smaller Barder, MTW, or KC would probably be much more worth it to you.
Sent from AutoGuide.com App
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #8 of 52 (permalink) Old 07-15-2014, 05:54 PM
I would never run a cast wheel pmax on my truck. That cast wheel is garbage. I have even had pmax turbos that were out of balance right from the factory. If you buy a pmax then you need to put on a billet wheel... and then it is always a good idea to get it balanced.
If you never plan on going bigger than 155s then a turbo with the larger 13 bladed turbine wheel will serve you well... unless you are really hoping for the loud whistle or you might step it up to 175s or larger... then make sure to get a turbo with a 10 bladed turbine wheel.
13 bladed turbine turbos
MTW stage 1
Barder Stage 1
KC Stage 1.5
10 bladed turbine wheels
MTW stage 2
Barder stage 1.5 or 2
KC stage 2
It can get a little confusing because there is no set standard for "stages" of turbos
peixinho is offline
post #9 of 52 (permalink) Old 07-15-2014, 07:13 PM Thread Starter
jdrescher's Avatar
Thanks for all the useful info guys! It's a big help! !
post #10 of 52 (permalink) Old 07-15-2014, 09:09 PM Thread Starter
jdrescher's Avatar
who puts together these kc turbos never heard of them thanks!
