Air in hpop - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-12-2014, 03:30 AM Thread Starter
Air in hpop
Put a new updated hpop on my 04 6.0. My mechanic said my truck will have a little trouble starting for a day or so because of air in the hpop. Has anyone ever experience this?
hzippere is offline
post #2 of 15 (permalink) Old 07-12-2014, 03:42 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Air in hpop
Yes, any time your HPO system is opened up, it'll take some time to get the air purged out. Drive it hard a bit and it'll eventually purge itself out.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 15 (permalink) Old 07-12-2014, 11:21 AM Thread Starter
Re: Air in hpop
Thanks. Just checking. Still new to the diesel world just learning as I go.
hzippere is offline
post #4 of 15 (permalink) Old 07-15-2014, 12:48 AM
Re: Air in hpop
Should only take a few minutes of aggressive driving. Not days.
lenzhotrod is offline
post #5 of 15 (permalink) Old 07-15-2014, 06:59 PM Thread Starter
Re: Air in hpop
I can't drive the truck hard right now due to the motor has been remanufactured an bored .020 over. I'm still in the break in stage.
hzippere is offline
post #6 of 15 (permalink) Old 07-15-2014, 07:05 PM
Re: Air in hpop
I grew up with a saying " break in a motor fast and you will have a fast motor, break in a motor slow and you will have a slow motor". Break in are for bad machining and irregularities. Many race motors are given the break in down the quarter mile!
post #7 of 15 (permalink) Old 07-15-2014, 08:30 PM
06.0dually's Avatar
Re: Air in hpop
Do the .020 over motors run much better than a stock motor? Any more hp ? And do they sound much different?
06.0dually is offline
post #8 of 15 (permalink) Old 07-15-2014, 11:24 PM Thread Starter
Re: Air in hpop
Fuel mpg got a little better. Other than that haven't put a load on it to see a difference.
hzippere is offline
post #9 of 15 (permalink) Old 07-15-2014, 11:28 PM
Re: Air in hpop
no. not really measureable. and no
.020 over bore is to repair damaged /worn cylinder wall the difference in size is insignificant. The only real gain is from restoring ring seal and compression to specification
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #10 of 15 (permalink) Old 07-15-2014, 11:30 PM
Re: Air in hpop
Correct the engine will have an extended crank for a while, until the hpo system is free of air. 10-15 miles @ highway speed is all that is necessary
wise guy is offline
