Racor ccv4500 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 07-10-2014, 10:21 PM Thread Starter
Racor ccv4500
Trying to install this bad boy on my truck, I can't find a plug to fit the lower drain, anyone have any ideas? Has anyone installed one of these recently?
05_HARLEY_F250 is offline
post #2 of 14 (permalink) Old 07-10-2014, 11:15 PM
Administrator
Zmann's Avatar
Re: Racor ccv4500
I have one but didn't get the plug
yet
look in the plumbing isle near the angle stops i thought it was like a 3/8 compression style fitting
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 14 (permalink) Old 07-11-2014, 10:04 PM
Re: Racor ccv4500
I have a complete new unit somewhere if I can dig it up I will measure it. You are wanting to know the thread size on the bottom drain valve? Heck,maybe the paperwork in the box might have a size listed! What size unit do you have? I know mine was the 4500.
lenzhotrod is offline
post #4 of 14 (permalink) Old 07-11-2014, 10:37 PM Thread Starter
Re: Racor ccv4500
It is the 4500, I've looked up all of their pdf's on this unit, all I can find is a drain hose kit, as you know most everyone mounts to the frame which is lower than the oil pan so the drain back kit is useless to me. I've torn lowe's apart for a fitting, to be more precise, the cap to go on the drain, nothing fit. I was planning on ordering the inlet/outlet barbs from racor so I'm not worried about that, it's that drain I need to figure out and at this point I'm wondering if a quick valve with a nut trimmed down on the inside may be the easiest way.
post #5 of 14 (permalink) Old 07-12-2014, 04:50 AM
Administrator
Zmann's Avatar
Re: Racor ccv4500
the pressure is small a hose and clamp would work
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 14 (permalink) Old 07-12-2014, 04:59 AM
Administrator
Zmann's Avatar
Re: Racor ccv4500
the fittings thread type and size is listed in this pdf page 9 apparently it's a check valve also
http://www.google.com/url?sa=t&rct=j...nIidzy_BLrlbVA
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #7 of 14 (permalink) Old 07-12-2014, 12:34 PM
HP MACHINE's Avatar
Re: Racor ccv4500
Anybody have pics of one mounted ? I would like to keep mine up under the hood somewhere .
HP MACHINE is offline
post #8 of 14 (permalink) Old 07-12-2014, 12:44 PM
Swamp trash...
Merc82's Avatar
Re: Racor ccv4500
[IMG][/IMG]
It is a big Mama Jama. I picked mine up used from a member on the ORG. He pulls them off buses before they get scrapped. I have a valve on mine to drain it. I copied his set up. It came with all the CCV hoses and I modified them to work and it came out fine. I had to cut the mounting tabs off to make it fit here.
Chris. 06 LBCC XL 4◊4
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #9 of 14 (permalink) Old 07-18-2014, 10:46 PM
Re: Racor ccv4500
Anyone know if that is a flare x male fitting? The picture sure looks like a 45 degree flare end. I show one in my catalog as a 3/8" flare x 1/4 male ball check valve.
FaSSt9602 is offline
post #10 of 14 (permalink) Old 07-20-2014, 04:47 AM Thread Starter
Re: Racor ccv4500
I thought so too, but no flare fittings at lowe's seem to fit it, it's gotta be something else.
I'm over it, the fitting coming out of mine didn't have a valve and I couldn't find a cap so I ordered a F106 fumoto quick valve and the 106 extension that intend on cutting down to make a nut for the inside. Both came with gaskets, I'll be using those against the both sides of the filter housing.
