BPD HD Oil Cooler Question / Clarification - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 07-10-2014, 08:44 AM Thread Starter
Diesel Addict
kaniper sniper's Avatar
Ok.. I'm interested in the BPD HD kit. Does it completely delete the factory oil filter since it has a better micron spin on one? Also, heard continued issues of oil temps above 240 when towing heavy due to a lack of air over surface area of cooler. Any way to remote mount a larger cooler in the bed or against the framerail with an electric fan big enough to put EOT in a choke hold .. No matter what weight and OAT you torture it with ? Thanks for your wisdom in advance
2005 F250 CC SB SRW 4x4 Build Date 02/05 Diamond eye 4 in DP to a 5 in exhaust, SB Intake, SCT 3015, CTS Insight, Blue spring, Sinister Coolant Filter, CCV Mod, Harley Lights, 138k mi and counting
kaniper sniper is offline
post #2 of 14 (permalink) Old 07-11-2014, 06:56 PM Thread Starter
Diesel Addict
Re: BPD HD Oil Cooler Question / Clarification
Anybody ?
post #3 of 14 (permalink) Old 07-11-2014, 08:20 PM
Yes the BPD oil cooler system removes the old filter and uses the spin on. Yes temps can be an issue especially here in AZ... Get a 1997 7.3 diesel machanical fan clutch and BPD adapter and call it a day.
Beewoody is offline
post #4 of 14 (permalink) Old 07-11-2014, 09:22 PM
Sponsor
Sentinel@BPD's Avatar
Great question!
We have two options for our kits: one that eliminates the factory oil filtration and uses the Bullet Proof Diesel oil filtration, (which is the one we highly recommend) or retains the OEM oil filtration.
We also have the fan clutch adapter that allows you to implement a 1997 7.3 fan clutch (mechanical) to your system.
​Questions? Comments? Please contact us!
Visit us @
"Like" us on
Follow us on
Sales: 888.967.6653
post #5 of 14 (permalink) Old 07-12-2014, 03:11 AM Thread Starter
Diesel Addict
Thanks for the input. Trying to put a larger remote mounted oil cooler with a fan in the bed would be impossible or overkill?
post #6 of 14 (permalink) Old 07-12-2014, 03:58 AM
'05 Excursion
Term3's Avatar
Personally I think it's a bad idea due to the extended amount of time it would take your oil to fill and get up to pressure with all those extra feet of lines after being shutdown.
Sent from AutoGuide.com App
Term3 is offline
post #7 of 14 (permalink) Old 07-12-2014, 06:41 AM Thread Starter
Diesel Addict
That's true Term.... I've seen remote mounted oil and tranny coolers mounted in beds and on roll cages on rock crawlers and trophy trucks and didn't know if that same concept could be replicated with the BPD kit
post #8 of 14 (permalink) Old 07-12-2014, 04:00 PM
'05 Excursion
Term3's Avatar
I think it would be ok if you had an oil accumulator that you could discharge before every startup or if you had an electric pre-luber like I have.
Term3 is offline
post #9 of 14 (permalink) Old 07-13-2014, 07:43 AM Thread Starter
Diesel Addict
Where did you pickup your electric preluber ? What brand? And how exactly does it operate? I.E. Does it cycle on with your glow plugs or do you have it hard wired to a manual switch?
post #10 of 14 (permalink) Old 07-13-2014, 05:19 PM
'05 Excursion
Term3's Avatar
I picked it up about 12 years ago, don't recall the manufacture. It has a controller that starts the pump as soon as the key is turned or I hit the remote start for the truck. I have it adjusted so when I use my remote start it runs until a few seconds after the truck is started. After the truck is shutdown it runs for three minutes, also adjustable. I use 1/2" stainless steel tubing connected in place of the drain plug as I didn't care for the supplied rubber hose. I also have a switch that I can turn it on which makes oil changes a standup job. :)
Term3 is offline
