JGC Parts Delete Kit? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-06-2014, 05:34 PM Thread Starter
I found a guy to do my EGR delete kit and he said he likes to install this particular kit that is $80 from JGCParts. He said he hasn't had any problems with it and recommends it to all of his customers. Anyone out there ever used this kit?
Ford 2003 2007 F250 350 6 0L EGR Basic Bypass and Delete Kit Powerstroke Diesel | eBay
Thank you!
jspivak6.0 is offline
post #2 of 6 (permalink) Old 07-06-2014, 11:57 PM
Swamp trash...
Merc82's Avatar
Re: JGC Parts Delete Kit?
Never heard of them... Kinda leary of eBay stuff... But it's a pretty simple kit. This isn't a very hard procedure if you have a spare day available to do it yourself.
Chris. 06 LBCC XL 44
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #3 of 6 (permalink) Old 07-07-2014, 03:03 AM Thread Starter
I saw one of Hewitt's videos that that type of delete kit may or may not cause a Y-Pipe crack because the up pipe is blocked off instead of installing a new up pipe. However my mechanic I'm using said he recommends the kit and go doesn't see it being a problem.
post #4 of 6 (permalink) Old 07-07-2014, 10:38 PM
get the kit with the up pipe the puck will crack your up pipe!
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #5 of 6 (permalink) Old 07-08-2014, 02:27 AM
Big dumb redneck
6speedSD's Avatar
Garage
Spend the extra coin and get the solid stainless uppipe. Don't skimp out. You'll just be back in the shop later replacing it, and I'm sure labor costs the second time around will be more than just buying a decent delete kit up front.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #6 of 6 (permalink) Old 08-26-2014, 05:24 AM
MT KingRanch's Avatar
I found this kit also, am getting Sinister Y-pipes installed with studs, am thinking is good enough if you don't have to mess with the up pipe plug, hopefully coolant line is pressed into blockoff plate good enough. Might pick it up, don't need the up pipe.
MT KingRanch is offline
