What is this? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 07-03-2014, 12:18 AM Thread Starter
Strokin2004's Avatar
What is this?
Hey all, I was looking around the engine bay and saw this line that appears to be tapped into another line/hose. it is zip tied all the way to the drivers side and runs into the cab by the gas pedal. Haven't found the end yet in the cab, but supposedly the truck had some gauges at some point.
Strokin2004 is offline
post #2 of 12 (permalink) Old 07-03-2014, 03:48 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: What is this?
Pic not working for me....
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #3 of 12 (permalink) Old 07-03-2014, 05:18 AM Thread Starter
Re: What is this?
post #4 of 12 (permalink) Old 07-03-2014, 07:57 AM
Weatherlite's Avatar
Garage
Re: What is this?
Kinda hard to tell what it is hooked up to, but based off the type of connection and tubing, that is for some sort of aftermarket pressure sensor...that or I suppose it's possible that line actually flows something through it, but to what? lol I know the heater line shutoff valve is right there. If it's tied into there somehow then I would suspect it was for a cooling system pressure gauge. Without more detailed pics it's impossible to say for sure.
Weatherlite is offline
post #5 of 12 (permalink) Old 07-03-2014, 10:18 AM
whistle tits
ghohouston's Avatar
Re: What is this?
it appears to be where someone tee'ed into the map sensor line to install a boost gauge.
ghohouston is offline
post #6 of 12 (permalink) Old 07-03-2014, 02:37 PM
Re: What is this?
"Cooling system pressure gauge" ???
mattmankow is offline
post #7 of 12 (permalink) Old 07-03-2014, 06:38 PM
Big dumb redneck
6speedSD's Avatar
Garage
Re: What is this?
Boost gauge. Easy was is to tap into MAP line, which is how that one is. I'd find the end inside the cab and make sure it's plugged. If not, that's a boost leak. Lik
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
BPD FICM
6speedSD is offline
post #8 of 12 (permalink) Old 07-03-2014, 07:11 PM Thread Starter
Re: What is this?
6speedSD I will definitley look for the end ASAP. The truck had gauges at one point but not when I bought it. Thanks
post #9 of 12 (permalink) Old 07-04-2014, 12:24 AM Thread Starter
Re: What is this?
Definitly looks like a boost gauge line that was not plugged. Found all these by the A pillar with just electrical tape wrapped around them. Now to figure out what the others are.
post #10 of 12 (permalink) Old 07-04-2014, 12:39 AM
Roenicke95stroker's Avatar
Re: What is this?
Yeah deff a boost gauge
Roenicke95stroker is offline
