Can the Speedo be calibrated on a 6.0 2004 F250?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-02-2014, 04:24 PM Thread Starter
ive been looking thru the site but havent found out how exactly to do this with out going to the dealership. Help would be appreciated!
2004 F250 2WD Crew Cab
S&B intake
Diamond Eye Exaust 5"
Sinister EGR delete
Blue spring mod
SCT livewire TS
LSMAFIA is offline
post #2 of 6 (permalink) Old 07-02-2014, 04:28 PM
Administrator
Zmann's Avatar
Re: Can the Speedo be calibrated on a 6.0 2004 F250??
it's done through the OBD ( as you know) you need someone who can access the ABS module
like a dealer or an Automotive Engiuity setup (Google)
then there is the signal manipulator like the truespeed units by superlift ETC
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #3 of 6 (permalink) Old 07-02-2014, 05:07 PM Thread Starter
Thanks man ill look them up! either of these dont affect the tuner right? the shift points should be fine as long as i have the Gear ratio and Revs/Mile set in the tuner?
S&B intake
Sinister EGR delete
Blue spring mod
SCT livewire TS
LSMAFIA is offline
post #4 of 6 (permalink) Old 07-02-2014, 09:38 PM
Administrator
Zmann's Avatar
that should be correct
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #5 of 6 (permalink) Old 07-03-2014, 11:09 AM
jtgf250's Avatar
I use AE. Its great and plus then you have your own scanner anytime you need it. I will say that with AE, when setting for different tire size, I had to set it as alittle smaller to get it to read as close as possible. Checked it with my gps after setting and made adjustments as needed.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #6 of 6 (permalink) Old 07-10-2014, 12:41 AM
I also have A/E and love it except I cannot seem to adjust my speedo against a GPS. I notice different shifts times at different speeds but overall speedo remains the same! I have often wondered if I need to retune back to stock then use the A/E?
lenzhotrod is offline
