CCV Mod? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 06-30-2014, 05:49 AM Thread Starter
CCV Mod?
Hello All,
I have a 2006 F250 with Banks Technicooler, Banks 6gun, Banks IQV2 with speedbrake, AFE intake, MBRP T-back 4 in exhaust. She is a late model 06, so she got most if not all the mods done by International, to the engine. I am looking at doing a CCV Mod, and want some advise. Rather than just porting the CCV out the bottom, what is your take on using a air compressor line dryer as a catch? I am looking at a protected bowel unit, so that's not an issue. Thanks in advance!
Koplinhagen is offline
post #2 of 12 (permalink) Old 06-30-2014, 10:44 AM
Swamp trash...
Merc82's Avatar
Re: CCV Mod?
Just picked up one of these. It's the best you can get:
https://www.google.com/url?sa=t&sour...koMkO9o_e9ueUg
Chris. 06 LBCC XL 44
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #3 of 12 (permalink) Old 06-30-2014, 12:35 PM
Re: CCV Mod?
An air dryer requires pressure to work, Your CCV does not like pressure.
lenzhotrod is offline
post #4 of 12 (permalink) Old 07-03-2014, 03:38 AM
Re: CCV Mod?
You can also run one of these units also. Very well made and not as pricey as the Racor. Saikou Michi Co. 2013
Eddy is offline
post #5 of 12 (permalink) Old 07-03-2014, 08:01 AM
Weatherlite's Avatar
Garage
Re: CCV Mod?
I made mine out of 2 1/2" PVC, some hose and a brass drain valve. Total cost was less than $25. Works like a champ.
Weatherlite is offline
post #6 of 12 (permalink) Old 07-07-2014, 11:32 PM
Swamp trash...
Merc82's Avatar
Re: CCV Mod?
Threw my Racor together last weekend. It's a heavy duty unit. Here's a pic:
[IMG][/IMG]
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #7 of 12 (permalink) Old 07-08-2014, 02:25 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: CCV Mod?
That effin thing is massive!
I just bought a little $15 strainer from TSC. Used for spray rigs I think. Nothing fancy...doesn't keep ALL the oil out, but it catches the majority of it. Anything is better than nothing. I'll eventually upgrade....bottom of my to do list currently. I had it just dumped under the bed at first...couldn't take the stink any longer.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #8 of 12 (permalink) Old 07-08-2014, 11:25 AM
Swamp trash...
Merc82's Avatar
Re: CCV Mod?
That's what she said!!!!
Gets the job done.
Studded and deleted
Oringed heads
S2 turbo
190/30 injectors
ported intake
amsoil bypass
PHP gryphon
SCT X3
Merc82 is offline
post #9 of 12 (permalink) Old 07-08-2014, 01:16 PM
Wheelhop's Avatar
Re: CCV Mod?
[IMG][/IMG]
Thats a good looking install, but what is it mounted to? The angle of the pic doesn't show the mounting bracket.
Wheelhop is offline
post #10 of 12 (permalink) Old 07-08-2014, 01:51 PM
Re: CCV Mod?
That's great, but what about those of us with a coolant filter? Anyone have one installed anywhere else on the truck? I had one from a company that mounted in that spot, I ended up taking it off because it didn't fit right. the hoses were kinked and starting to split. Ive never gotten around to mounting it anywhere elses.
mattro is offline
