225/100 injectors running hot - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 54 (permalink) Old 06-27-2014, 09:36 PM Thread Starter
06.0dually's Avatar
Has anyone ran 225/100 6.0 injectors and they are running hot? egts? oil temps?
I personally have 225/100 warren injectors, and ive heard people saying they run hot so they move up to a 285/150.
Ive tried to research this topic, and found that no one directly adresses this subject.
06 f350 white crew cab dually, 225/100 warrens, barder 68, BTS, Fuel lab setup built by tsd, sct tuned by tsd, ppe up pipes,bd exhaust manifolds, secret dual oil kit ,CTS monitor, a lot more extras
01 f350 red extended cab dually, powermax 38r, BTS, cfm, Afe, 6 inch danahoe, tsd 6 pos, a lot more extras.
06.0dually is offline
post #2 of 54 (permalink) Old 06-27-2014, 10:02 PM
JGman141
Jgman141's Avatar
Re: 225/100 injectors running hot
What's your icp reading
Jgman141 is offline
post #3 of 54 (permalink) Old 06-27-2014, 10:28 PM Thread Starter
06.0dually's Avatar
i havent picked my truck up yet, but a friend from tsd was running the same injectors and they were running hot. The only diffence is i have a rcd thumper hpop which should help with the oil. He was not running any aftermarket hpop,and still is not.
he told me he recently moved up to 285/150s and they run alot cooler.
post #4 of 54 (permalink) Old 06-27-2014, 10:35 PM Thread Starter
06.0dually's Avatar
The 285/150's he moved to are hybrids. And these are all warren injectors im talking about.
My 225/100s are conventionals .
post #5 of 54 (permalink) Old 06-27-2014, 10:46 PM
HMMM
toys here:
"Life is not a journey to the grave with the intention of arriving safely, in a pretty and well preserved body, but rather to skid in broadside, thoroughly used and worn out, loudly proclaiming, "WOW!!! WHAT A RIDE!!!"
EXCAV8TER is offline
post #6 of 54 (permalink) Old 06-27-2014, 11:25 PM Thread Starter
06.0dually's Avatar
Does anyone know if they make a coolant thermostat that goes lower than stock temps? Such as a aftermarket thermo. I've seen the oil ones, but do they make coolant thermo's?
post #7 of 54 (permalink) Old 06-28-2014, 12:04 AM
JGman141
Jgman141's Avatar
If your oil is getting hit I'd take a look at your oil cooler, all my temps stay in check except egts. Do you have any specifics of what your temps are hitting?
Jgman141 is offline
post #8 of 54 (permalink) Old 06-28-2014, 01:22 AM Thread Starter
06.0dually's Avatar
I'm just worried about my coolant. I just got a new mishimoto radiator and intercooler that is going on my truck . That's why I was wondering about the coolant thermostat, and to help keep the temps lower.
My coolant sits about 206 and hits about 210, but I also have a crew cab dually. It hits 210 without towing . I haven't towed with it to read those temps. Those temps were without the new radiator. It is also without the new injectors to. Tsd said my truck might run a little hot because it's a dually and I got 35s on it.
post #9 of 54 (permalink) Old 06-28-2014, 01:24 AM Thread Starter
06.0dually's Avatar
I'm also putting on a sinister oil cooler as we speak. So far I don't think the oil is getting to hot. Just in case I got the cooler.
post #10 of 54 (permalink) Old 06-28-2014, 01:46 AM
I would first check for a biased temp sensor. Also with diesels if you add more fuel without air, heat will be produced!
lenzhotrod is offline
