MDP s400 turbo drain - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-10-2014, 10:48 PM Thread Starter
blowing smoke
rollingcoal's Avatar
Has anyone with a s400 used maryland diesels turbo drain ? Having problem with the aluminum plug that goes into hpop cover coming out and spilling oil everywhere without warning . What types of drain setups is everyone else using cause this is getting old quick .
rollingcoal is offline
post #2 of 6 (permalink) Old 06-12-2014, 12:57 AM
06-6.0 stoker's Avatar
Re: MDP s400 turbo drain
I've got the aluminum fitting your talking about on my big truck. I've had it in and out several times switching turbos and things like that I've never had one issue with it sealing. There shouldn't be excess pressure at all causing it to pop out. That's a easy drain in with the hpop like that. Maybe the oring is the wrong size?
Sent from AutoGuide.com App
2006 f250 4x4 6in lift 37x13.5 tires
A few engine parts here and there
Back Road Performance tuned
06-6.0 stoker is offline
post #3 of 6 (permalink) Old 06-15-2014, 02:55 PM
Diesel Addict
02POWERSTROKE7.3's Avatar
I had that same kit on my truck with a s472 with no issues.
2002 F250 7.3 Powerstroke
02POWERSTROKE7.3 is offline
post #4 of 6 (permalink) Old 06-15-2014, 07:07 PM Thread Starter
blowing smoke
When it in like it shud be it still has slack and the hose supplied in kit is swollen .
post #5 of 6 (permalink) Old 06-15-2014, 11:52 PM
The hose swells when the truck is running and the hose goes back when the truck is shut off?
post #6 of 6 (permalink) Old 06-25-2014, 06:34 AM Thread Starter
blowing smoke
No hose isnt oil resistant and is swollen . Does not go back to normal.
