Diamond eye exhaust heads up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-07-2014, 11:35 PM Thread Starter
06 FX4,4" Rough Country
Bleed Blue's Avatar
So I recently put a 4" dp and 5" complete system from diamond eye on my truck and it was just about the death of me. The dp fit on fine, the problem was connecting the mid pipe to the down pipe, going from 4-5". For some reason they have 3 adapters that go between the dp and mid pipe to connect them. I had everything perfectly pushed tight together and began tightening the clamps and it just caused a mess. All the cupplings wouldn't cinch down tight and they kept coming loose, finally just getting so bent out of shape they couldn't possibly hold tight. So after 7 hrs my truck was still useless. The next day had to have a friend come weld everything up and now it's fine. Just wondering If anyone else has experienced this bc it was awful!
06 F250 CCLB FX4, 173K, Egr delete, Blue spring, SCT performance tune, AFE cold air, 4" Rough Country, 35x12.50 Cooper STT m/t, Fuel Hostage 18x12 -44 offset, 4"dp into 5" Diamond Eye system
Bleed Blue is offline
post #2 of 7 (permalink) Old 06-07-2014, 11:57 PM
Re: Diamond eye exhaust heads up
I installed a diamond eye 4" turbo back system on my excursion and I endednup welding it together to cause it kept coming loose. I like the setup and has been trouble free for me the last 4 years.
ExToy is offline
post #3 of 7 (permalink) Old 06-08-2014, 11:56 AM
PursuitInterceptor
HeavyAssault's Avatar
I'd contact Diamond Eye to get a better answer on your compliant. I do appreciate giving other consumers a heads up on the issue.
Sometimes bigger isn't always better.
You see, in this world there's two kinds of people my friend....those with loaded guns, and those who dig.
You dig.
HeavyAssault is offline
post #4 of 7 (permalink) Old 06-08-2014, 09:15 PM
09 6.4
webb06's Avatar
i always tack weld every joint and never use the junk clamps they include in the package. ive installed several of these diamond eye exhausts and never have much trouble with fitment.
2009 CCSB Black
6.4
12.6 @ 109 1/4 mile
webb06 is offline
post #5 of 7 (permalink) Old 06-09-2014, 03:30 AM
Big dumb redneck
6speedSD's Avatar
Garage
Same kit as you on mine. Fitment is really well, but the clamps are just junk. Had the same issues with Silverline on my old truck. Don't get when they always skimp on hardware.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #6 of 7 (permalink) Old 06-09-2014, 06:48 AM
Yfz rock's Avatar
I have the same exhaust and mine is awesome fitment clamps are tight as can be
2006 f350 CCLB
Blue spring mod
6.4 Banjo bolts
Zoo dad
SCT 3015 BRP Raped ape Tune by Drew
Diamond eye 5 inch turbo back
Afe blade runner charge pipe
5w40 Rotella T6
SOLD!!!
2008 f350 CCLB 6.4
S&B intake
rest is on lock for spring 2015 :)
Yfz rock is offline
post #7 of 7 (permalink) Old 06-09-2014, 01:19 PM Thread Starter
Bleed Blue's Avatar
Thanks for the feedback, all my fitting was tight. Just bad clamps I guess
